Somewhat of a S-Tech problem.
Old Aug 9, 2004 | 07:51 PM
SCIONbrouillard's Avatar
Default Somewhat of a S-Tech problem.
I noticed that my springs/shocks on the front driver side are a 1/4 of an inch lower than the other springs/shocks.
What's wrong or is this normal since I'm almost always the only one in the box.
If this is an obvious problem then don't mind me since I'm not a mechanic.
Old Aug 9, 2004 | 08:06 PM
bB384's Avatar
IV ACE
Your xB should be lowered 1.7 inches in the front and 1.5 in the rear. So you should notice that the front is lowered more than the rear. But there shouldn't be a difference from left to right.
Old Aug 9, 2004 | 08:17 PM
Minsk99's Avatar
Make sure you are on a very flat surface when measuring. Even a slight incline will show in the height of the suspension. Also, how long ago did you install the springs? Perhaps on side "settled" faster then the other.
Old Aug 9, 2004 | 08:19 PM
The front driver side is a 1/4 of an inch lower than the front passenger side. Thus making the car look weird and lopsided.
Old Aug 9, 2004 | 08:20 PM
It was installed on Sunday, August 1, 2004.
Old Aug 9, 2004 | 08:52 PM
superjeer's Avatar
hmmm.. maybe the higher spring got twisted around so it's not in it's seat? Try pulling the wheel and taking a look.
Old Aug 10, 2004 | 06:04 AM
J_A_Trevino's Avatar
the same thing happened to me with my previous vehicle, when i lowered it the spring wasnt set properly and the truck looked lopsided. try adjusting your springs and make sure they are set right in the strut.
sciontc008
Scion tC 1G Aero & Exterior
Jan 20, 2016 05:10 PM
Forced4
Aug 25, 2015 08:18 PM
hata
Aug 24, 2015 06:02 PM
TheRealShark
Scion tC 2G ICE & Interior
Aug 5, 2015 05:08 PM
