Big Question About Springs
Old Aug 18, 2004 | 07:22 PM
Hate_adict's Avatar
Default Big Question About Springs
Whats happening? So I have an xB and I just ordered Tein S tech Springs. (I'm in NJ) And I'm calling around and NO places install lowering springs. Just wondering what kind of things need to be adjusted (whatever that thing is that can make you tires slant inwards) and for those of you who have slammed your xB, what did the shop say they had to do?? How hard is it to get it done yourself. My friend said he'd do it for $150 without an alinement. So I would be paying over 200 just to install $150 springs!! WTF. Wasnt there people installing for like $50?? Thanks.
Old Aug 18, 2004 | 07:24 PM
SUPASCIONXB's Avatar
damn too bad u dont live in ny i would do it for 50 and a six pack in about an hour.
Old Aug 18, 2004 | 07:28 PM
Hate_adict's Avatar
Dont you need a spring compressor?
And are you serious dude, i'd drive up there. Where in NY?
Old Aug 18, 2004 | 07:29 PM
TheDanger's Avatar
$150?! Wow...I have heard of shops doing it with alingment for $80...that's professional done. It isnt the hardest thing to do in the world..I think there is a how to in the tech section.
Old Aug 18, 2004 | 07:31 PM
TheDanger's Avatar
here the link...and yes you do... https://www.scionlife.com/forums/viewtopic.php?t=20769
Old Aug 18, 2004 | 07:33 PM
no spring compressor needed here check this out this is a great guide for doing it yourself
Old Aug 18, 2004 | 07:35 PM
Originally Posted by TheDanger
you do not need a compressor for this install
Old Aug 18, 2004 | 07:37 PM
WileECoyote's Avatar
EZ to do yourself. Just becareful when undoing the nut that holds the spring perch on for the front struts.
Yeah, follow the directions in the tech forum.
Do NOT pay $150 for spring install. Get your wheel alignment (you only need front end alignment) at your Scion dealer, around $40. You don't need rear alignment, because its just a solid beam back there, it doesn't move (camber.)
Old Aug 18, 2004 | 07:47 PM
Hate_adict's Avatar
Thanks for all the info. But I dont know about doing it myself, I dont have all the tools i need etc. I think I'd rather pay for it done.
Are there any franchise places (like Jiffy Lube) that would do it or are you only talking about performance shops? Also, do you think a Toyota dealer would do it....cheaply??
Old Aug 18, 2004 | 07:55 PM
Nathant888's Avatar
DeepSouth Scions
There is no way, the Toyota dealer charges out of the crack of their ___. They want $639 for TRD Springs installed . I am driving to Ft. Smith (One Hour Away) to a authroized Tein dealer and have them installed..
-nt
Old Aug 19, 2004 | 02:05 AM
TheDanger's Avatar
Most of the tools you would need you could rent from autozone for free with the secruity deposit you put down and you get back once you return the item...or find a tire place should be able to do them. Or a custom shop that sells wheels.
Old Aug 19, 2004 | 02:45 AM
Back_In_Black_xA's Avatar
You don't really need that many tools. All you need to basically get it done is...
-12mm wrench for the strut tower nuts (you can get at those nuts with this and don't have to remove the wiper cowl or anything).
-14mm socket/rachet for brake line bracket bolts
-17mm socket for rear shock nut and torsion beam nut, and front strut nuts
-19mm wrench and socket for the front strut bolts which hold it to the knuckle
Thats about it. I mean it always helps to have a lot of tools on hand, I used a lift, 1/2 impact wrench (just for the wheels), 3/8 impact for all the bolts/nuts, wall mounted spring compressor, vise grips to hold the spring in place when you tighten the nut (because it can move sometimes), and probably other stuff to.
Old Aug 19, 2004 | 02:52 AM
Some things that bother me about this that are not included and are important are...
-Undo the 14mm bolt for the brake line brackets. When you press down on the rear end the brake line gets very close to completely running out of slack. Do yourself a favor and take off that nut so the line has more slack and you don't break or damage your line. Also you shouldn't even need to take off the wheels in the rear, I didn't have to. Also they never tell you to zero the preload on your torsion beam bushings which will cause them to tear after a while if you do not undo that bolt, put the car on the ground, than tighten the bolt.
TotalChaos
13
Feb 4, 2015 10:24 PM
STCxB
11
Jan 9, 2015 04:30 PM
Scionxa180
16
Dec 8, 2014 04:00 PM
scioninla
14
Oct 18, 2003 03:46 AM
Besk_one
Oct 16, 2003 07:45 PM
