How can I replace my tC tweeter? Warrantied? Where to get?
Old Mar 8, 2007 | 03:30 PM
jglonek's Avatar
Default How can I replace my tC tweeter? Warrantied? Where to get?
Ok, here's my story.
Last week I put in an iPod adapter to my 2005 tC. Which I guess boosted the audio quality enough to let me see that my passenger tweeter is bad, it's putting out static on all the songs.
So basically I just want to replace it. I have no problem using the stock OEM tweeters, but I'm not sure what to do about it.
Would the sound system be covered under warranty where I could just bring it into the dealer and they could replace it? Or would it be an expense that would be better for me to do myself?
And if it's better to do myself.. where can I buy a replacement tweeter? And how would I even get to it to replace?
Old Mar 8, 2007 | 03:31 PM
sddykstr's Avatar
Sound system is normally not covered, considered normal wear and tear. You can buy OEM tweeters from the dealer I'm sure and do the replacement yourself.
Old Mar 8, 2007 | 05:17 PM
all4degame's Avatar
you might as well buy some high quality aftermarket tweets and mids if you're going to purchase new ones.
Old Mar 8, 2007 | 05:52 PM
jglonek's Avatar
And if I do that do I have to worry about them fitting properly?
Old Mar 8, 2007 | 06:23 PM
nodsetse's Avatar
Yes, you will. You'll either have to ensure the new tweeters fit in the stock location, or make some modifications in order for them to fit. You'll also need new baffles to mount the new mids, but you can make them yourself or purchase those offered by companies such as eD.
Old Mar 8, 2007 | 06:44 PM
Shogun's Avatar
Default Re: How can I replace my tC tweeter? Warrantied? Where to ge
Are you sure that your tweeter is bad? CDs typically have better sound quality than songs put on iPods (unless you do your own encoding). If you did not hear static with CDs, then chances are your iPod cable is not high quality. Since you have a 2005, that means you do not have a direct hook-up, instead you use a headphone cord. There are many varying qualities of these, some of which are not shielded.
I should also point out, it is possible you put bad quality songs onto your iPod. Now, if they were downloaded from iTunes then there should be no problem. You need to see about the songs that you downloaded elsewhere or ones you ripped yourself. The iPod is not a high fidelity MP3 player. When people know how to encode songs they can get very good sound reproduction but the iPod does not use the processors for high fidelity sound.
My sister had a cavalier and the paint on the radio buttons would rub off. The dealer replaced the radio twice while it was still under warranty. When it happened for the 3rd time out of warranty...I put in an aftermarket headunit.
It may vary by dealer, but the radio should be covered. Speakers are not really wear and tear. Speakers last a long time. Unless they are abused, it takes many years for speakers to die. There would be no reason not to have them covered under the warranty.
Old Mar 8, 2007 | 08:16 PM
Zebman's Avatar
It is definitely your Ipod cable, or just the connection in general. If you can't notice it on store-bought CDs (1000+kbps WAV format), then it doesn't exist in your speakers.
Old Mar 8, 2007 | 09:23 PM
jglonek's Avatar
Well, honestly it's been a long time since I really listened to CDs. Most recently I've been doing an FM transmitter with my iPod.
I'll have to put in a CD of the same songs and see what I hear. Most of it was Evanescence that I ripped from my CD to my computer.
I only hear the issue coming from that one spot in the car though.. I'll have to see with the CD, it makes sense.
Old Mar 10, 2007 | 12:28 AM
Zebman's Avatar
FM Transmitter. Enough said. ;)
Old Mar 10, 2007 | 04:20 AM
amdforever's Avatar
I'm also having a similar issue with my tweeters in my '07. I admit I play my songs rather loud and I use my iPod as well. It seems that certain songs with a certain type of bass tend to make my do a kinda rattling like sound to them. I burned a mp3 cd and WOW does that SRT feature make your songs sound great. However I noticed the rattling getting progressivly worse. Started with the left tweeter on a few songs, then the right started and now they both do it. Called the dealer and he said they would check it out and replace if it wasnt caused by abuse and of course I told him it wasn't...there isn't anyway they would know right? Hope you get some help on your issue though man, but I know the FM trans for iPods usually suck anyway. I think mine is the actual speaker as it does it to both mp3 cd's and the iPod.
Old Mar 10, 2007 | 02:37 PM
Zebman's Avatar
That's probably one of the tC's many rattles you're experiencing. At the moment, i'm trying to find a way to rid my self of an OBNOXIOUS buzzing sound caused by the contact of two of the pieces of the door panel. I'm probably going to have to take it off again. Ugh.
Or is it actually sound related, and not adversly affected by the volume? (Meaning that it's there without crankin' the bass)
tato63
Scion tC 2G Wheel & Tire
9
Sep 30, 2015 09:55 PM
blh72
Scion xD Wheel & Tire
Feb 2, 2015 12:36 AM
torranosaurus
Jan 28, 2015 04:53 AM
lunchbx05
Dec 29, 2014 07:53 PM
