2011-____ [ANT20]
2011+ Scion tC Bulb Sizes
Old Jan 12, 2011 | 06:55 AM
Gapoy's Avatar
Default 2011+ Scion tC Bulb Sizes
2011-2013 Scion tC Bulb Sizes:
Low beam headlights: | H11
High beam headlights: | 9005
Fog lights: | H11
Brake lights: | 7443 CK
Front turn signals: | 7440
Rear turn signals: | 7440
Back up light(s): | 7440
License plate: | 194/168
Front side markers: | 2827
Map light (front): | 194/168
Dome light (rear): | DE3022
Trunk: | DE3022
2014+ Scion tC Bulb Sizes:
Low beam headlights: | 9012/9006
High beam headlights: | 9012/9006
Fog lights: | H11
Brake lights: | 194/168
Front turn signals: | 1156NA
Trunk: | DE3022
Old Jan 12, 2011 | 03:10 PM
greenbean24's Avatar
Low Beam Lights H11
Hi Beam Lights
Fog Lights. H11
Signal/Turn Lights
Dome Lights
Plate Lights
Old Jan 12, 2011 | 04:29 PM
Obie's Avatar
Originally Posted by greenbean24
Low Beam Lights H11
Hi Beam Lights
Fog Lights. H11
Signal/Turn Lights
Dome Lights
Plate Lights
Low Beam Lights H11
Hi Beam Lights 9005
Fog Lights. H11
Signal/Turn Lights
Dome Lights 175 I believe
Plate Lights 168 (t10 wedge)
Old Jan 12, 2011 | 07:33 PM
Gapoy's Avatar
THANK YOU GUYS!
Old Jan 12, 2011 | 11:28 PM
Superpickel's Avatar
Be sure to use the search function before creating these. There are plenty of threads already with bulb sizes
Old Jan 14, 2011 | 06:23 PM
excaka's Avatar
http://stores.mengmotorsports.com/-s...led/Detail.bok
Will these fit in the tC2 license plate light? I know on one website it said 194/168, are they the same?
__________
Old Jan 16, 2011 | 01:21 AM
yes, these bulbs will fit the license lamps along with the two front dome lights in the interior.
Old Jan 16, 2011 | 09:51 PM
excaka's Avatar
well i went for these ones.
http://www.v-leds.com/Exterior-LED/C...-p4481133.html
a few bucks cheaper. hope they do the same thing.
Old Jan 16, 2011 | 09:57 PM
excaka's Avatar
it says its a tad bigger then mengs. by like .6mm in height. anyone know if theres room to spare in the plate light housing?
Old Jan 16, 2011 | 10:18 PM
ImaKing88's Avatar
no i dont know but be sure to post pics once its installed
Old Feb 1, 2011 | 07:04 PM
Matariel's Avatar
What are the bulbs required for daytime running lights?
Can anyone confirm that they're the same as the hi-beam, 9005 size?
Thanks!
Old Feb 3, 2011 | 02:54 AM
Enzie's Avatar
Wait, I'm confused. So what number are the dome light bulbs?!?!
Old Feb 11, 2011 | 05:00 AM
kvnhmmd's Avatar
Originally Posted by Obie
Low Beam Lights H11
Hi Beam Lights 9005
Fog Lights. H11
Signal/Turn Lights
1 - Are the signal/turn lights the 175's as well? It kind of looks like your answer was left blank on that one.
2 - How about the brake lights? Able to convert those to LED?
3 - What size is the reverse light(s)?
4 - I do not want ANY standard bulbs in my car. I want ALL to be LED/HID. Is this possible?
5 - Thanks.
Old Feb 11, 2011 | 05:12 AM
biglilsteve's Avatar
I'd actually like to do the same...
Old Feb 11, 2011 | 11:05 AM
Enzie's Avatar
I changed all the dome lights, as well as the trunk light in my car to LED, after a bunch of trial and error i got the right sized LEDs to fit. AND TO ALL OF YOUR BENEFITS :D!!! I'll write what i have written on the invoice i got, and if you have trouble finding the right ones i can go to the website and circle the exact ones i got, but i have no time at the moment D: (got all my bulbs from superbrightleds.com)
For the front dome lights, i put the
- WLED-x6: 6 LED Wedge Base Buld-WLED-CW6: Cool White
^--- two of these cause the front dome has two bulbs
the rear dome light i put the
- 3022-x9: 9 LED Festoon Bulb-3022-CW94: Cool White
^--- one of these cause its a double ended wedge bulb thing. it has 9 bulbs in a little square thing. amazingly it fits perfectly in the housing.
the trunk light used
- 3022-x4: 4 LED Festoon Bulb-3022-CW4
^--- this one fits snuggly in the trunk housing, but it makes the switch alittle hard to press...
License Plate Bulbs used
- WLED-x6: 6 LED Wedge Base Bulb-WLED-NW6: Natural White
^----- Same as the front dome lights, just used the "Pure white" instead, it looks nice o:
Reverse Light used
- 744x-xHP3: 744x series 3-HP LED Wedge bulb - 7440-WHP3: Cool White
^----- This was a 7440 bulb, the hardest part is taking out the old bulb, mine fell into the frame of the car ._. but it looks good, i didnt see pure white, there was only this white (It's much whiter than the same cool white color used in the domes), a yellow, and a red.
If you noticed, the trunk light and the rear dome basically have the same size bulbs. The 9 bulb LED would not fit in the trunk because the housing is too narrow. And the 4 bulb would be too dull to be in the rear dome light.
Sorry if its worded weird, i woke up at 5AM to write a paper and then had the good idea to post this because i got an email from the forum, saying someone replied to this post xD
GOOD DAY!!
EDIT: If i can get around to it, i'll post a picture of each bulb in each housing
EDIT 2: The bulbs from this site are cheap in price, so im certain a more expensive bulb will give a more brilliant color, etc. But for my first LED swap, i think its fine. Don't get me wrong, these bulbs are great, but i just know there's always more expensive and better quality around. the same for way theres a better alternative to everything else :D
Old Feb 11, 2011 | 01:31 PM
Good write-up man...this will prove useful.
Anyone have word on all the rest of the exterior lights?...brake, reverse, signal, parking lights?
Old Feb 11, 2011 | 01:55 PM
Enzie's Avatar
Thanks, but yeah, i wish a write up was around when i bought them, i ended up wasting like $8 on bulbs that didnt fit!
And i would really like to see the brank, reverse, signal, parkers... Cause those are all i have left for the easy bulbs to swap D:
Old Feb 11, 2011 | 07:31 PM
kvnhmmd's Avatar
Yes, thank you, Enzie! Did you replace your license plate lights as well?
Definitely waiting to hear about the best LED swap for brake, reverse, signal and parking lights!
Old Feb 11, 2011 | 10:33 PM
Enzie's Avatar
No problem! it's a pleasure to finally do something useful xD.. But no, i dont have the license plate swapped to LED..
I too am waiting on someone to give a list of the bulbs for all those other great places.
Old Feb 12, 2011 | 03:00 AM
kvnhmmd's Avatar
Too bad all of those LEDs don't come in the Natural White 4,500k color. How much of a blue tint do you get with the Cool White 7,500k color?
Also, the switch being harder to press, why is that? Hopefully, it shouldn't be too big of a deal, since ultimately, the trunk light is controlled by the hatch opening and closing right? Most people would leave the switch on, I would imagine.
