Scion FR-S Forum - The Scion sport coupe
tC -> FR-S.....and I am back!
Old Jul 9, 2011 | 10:44 AM
  #181
JPfeffer's Avatar
Originally Posted by Scion202
Maybe I'll try to make a how-to on this in a bit.
^^^ This!
Old Jul 9, 2011 | 09:37 PM
  #182
Scion202's Avatar
Default 2nd in the series of bad DIYs
Converting Regular LED 7443 to CK type DIY#2
I bought this:
http://cgi.ebay.com/ebaymotors/2x-74...Q5fAccessories
Now these 2 diagrams have been floating aroung the internet and are provided by superbrightleds and they are both wrong:
In each picture, on each LED they messed up the Tail and Brake! Which in turn makes the diagram work for a wrong reason.......
In the socket below, the ground is Black/white, Green/white is brake and Green is Tail.
SOOO
If ground is on the top then brake is on left and tail on right, which the opposite in each of the diagrams.
To prove that the Regular LED wiring is wrong as well I used a 12V source and connected it to the Tail which produced moderate light and then took another 12V lead and connected it to the brake and it was glowing very bright!
First time I tried it(when I was following the diagram), it did not work, because the LED doesn't allow you to do it the other way around.
So the tail and the brake on the Regular LED were flipped as well. The brake was the one at the edge.
The best way to find Ground on the LED is to Check for Continuity between 2 leads until you find it.
So here is the corrected Diagram:
STEP1:
Bring the grounds on the same side, the side opposite from where the brake is:
Step2:
Cut the Tail light lead a little bit and solder an insulated wire to it. Solid 24 gauge wire works great. Then route it to the other side as far away from the brake as possible. Place some electrical tape over the soldering point:
So now it looks like :
Step 3. Make sure to find the ground on the socket and Plug in the bulB!
Notice that the ground side of the socket is different loking from the other one.
You may have to wiggle it a bit to get the wires to contact
YOU'RE DONE
Old Jul 11, 2011 | 03:11 AM
  #183
JPfeffer's Avatar
As always, thanks for the write up! Could I request a few pictures? Could we get daytime photos of your puddle lights and of your door panel bottle holder lights? I'd love to see how/where they're mounted and how they're sealed from moisture. Any chance we could get those?
Old Jul 11, 2011 | 08:31 AM
  #184
Scion202's Avatar
Yeah i've seen others ask me for the same pics I just keep running out of time cuz im working on other mods and in the process of moving into 2 different houses....
Here is a quick pick, I'll post explanations later
Old Jul 11, 2011 | 08:43 AM
  #185
Scion202's Avatar
Cool
$15 LED fogs
Spliced into parking lights
Parking&Fog LEDs
No lights/Parking and Fog LED lights/ Park&Fog&Headlights
What's nice about the fog leds is that they add corner light which is great during parkin/driving it gives almost 270 degree observing range.
This is what it looks like when locking and unlocking the car
Old Jul 11, 2011 | 08:55 AM
  #186
errol's Avatar
Wow thats badass! whered you get it
Old Jul 11, 2011 | 01:17 PM
  #187
MightyP's Avatar
Nice work! Love the double stack fogs
Old Jul 11, 2011 | 02:22 PM
  #188
jtk2's Avatar
yea looks awesome!! and is it just me or does you passenger side corner light look bluer than your driver side?
Old Jul 11, 2011 | 02:44 PM
  #189
KidJustin's Avatar
DaYUUM/Scion Evolution
i think we need a picture of ur car with ALL the LEDs on at one time
i'd imagine it's bright as f*ck and a helicopter could use it as a landing beacon
Old Jul 11, 2011 | 02:48 PM
  #190
jtk2's Avatar
i think hes seen that movie deck the halls. he wants his car to be seen from outer space!!! haha
Old Jul 11, 2011 | 02:52 PM
  #191
dhj517's Avatar
...someone told me you hate leds. just what i heard.
Old Jul 11, 2011 | 03:04 PM
  #192
m0ej0e's Avatar
I like the idea, I wanted some Fogs that would fill the whole area, not just a round light with a black backing. I like this better then the ones from dealer.
Old Jul 11, 2011 | 03:07 PM
  #193
Scion202's Avatar
lol same LEDs as I used in:
SunRoof
Speakers
Cup Holder
Trunk Additional Light
Puddle Lights
http://www.superbrightleds.com/cgi-b...FLS.htm#photos
Old Jul 11, 2011 | 03:10 PM
  #194
Scion202's Avatar
I think i see it haha....oh angles.....
I was gonna put 4 strips but the the lowest and the upper most wedges are shorter than the middle 2
Old Jul 11, 2011 | 03:28 PM
  #195
WellesleyScion's Avatar
Nothing planned so far I believe unless something comes in the mail on tuesday of course and then I got an install sesh. Im just reluctant driving any more then I have to. I already have 6.3k miles and my oil change is wednesday by which I'll probly have 400 more miles. I dont want toyota whining that i waited so long to come.
You mean you have a tire rotation and chassis lube on Wednesday??
Oil changes are at 10,000 miles on the tC2.
Old Jul 11, 2011 | 03:46 PM
  #196
m0ej0e's Avatar
My manual says 8,000KM for oil changes.
Old Jul 11, 2011 | 03:49 PM
  #197
Scratch's Avatar
Old Jul 11, 2011 | 06:23 PM
  #198
Scion202's Avatar
when I bought the car I was told to come in at 5k miles
The same is said in the manual
The sticker on my window says come in at 5001 miles or July 30th
Old Jul 11, 2011 | 07:55 PM
  #199
KidJustin's Avatar
told to come in, in general? or specifically for oil change?
because they told me to come in every 5k miles also...but for services in general, not specifically for oil change
@ 5k service is top off fluids/tire rotation
@ 10k service is same thing + oil change
...here is the warranty/maintenance book from scion.com
http://www.scion.com/assets/pdf/tC_O...guide_2011.pdf
go to page 37
it tells you the service done @ 5K then right next to it for 10K
exactly the same for both, except 10K has "Replace engine oil and oil filter" while 5K does not
Old Jul 11, 2011 | 09:48 PM
  #200
Scion202's Avatar
I've never had a new car before.... I just refer to any kind of maintenance as an oil change
