Autosports & Technique
General driving and racing...
Stock Quarter Mile Launch?
Old May 31, 2006 | 05:26 PM
MySupaWhitetC's Avatar
Default Stock Quarter Mile Launch?
Hey everyone, I'm heading down to the track next week Tuesday and I was wondering what you guys have been launching at. This will be the first time I'll be doing this, so really, I thought that I could get some info before I head down there. I'm going with a group of friends and I'm supposed to race a Mazda3 (wagon). Both of us are pretty much completely stock, I have the TRD exhaust, but I doubt it'll do anything to help my times. So yeah, any help would be great.
Thanks
Old May 31, 2006 | 05:28 PM
THansenite's Avatar
I was launching at around 2700-3000. The track was extremely hot that night though and nobody was getting any traction. Around 2700 seemed to work the best for me. The best thing to do is to make a couple of practice runs when you get to the track and see which launch RPM's give you the best 60 foot time. Good luck.
Old May 31, 2006 | 05:40 PM
DouBLeJ16's Avatar
I launch at around 3,000RPMs, sometimes slightly higher and then feather the clutch almost all the way through 1st gear.. I've hit several 2.2x 60' times on stock tires launching this way.
Old May 31, 2006 | 07:21 PM
Neothin's Avatar
3000 is also where I launched on stock tires. just slowly let the clutch out and add in gas accordingly. The tires will light up if you do it too fast, they don't have the greatest grip available ;)
Old May 31, 2006 | 07:27 PM
schwettynuts's Avatar
I thought hot track=more traction? Maybe im just dumb
Old Jun 1, 2006 | 01:42 PM
Ryhian's Avatar
I typicially launch around 2500-2700. Although im not on the stock tires(and running on 18's) I find minimal wheel spin at this range for me while still having good launching power. Ive tried all types of ranges and for me anything 3k or more is way too much spinning. But really its all in how you control the clutch on the launch.
Old Jun 1, 2006 | 04:49 PM
THansenite's Avatar
Hot tires = more traction. Cool track = better traction. If I remember physics correctly, the larger the difference in temperature, the better traction you will have (to a point). If the track is cool and your tires are hot, traction will be better. That is why you see all forms of automotive racing running faster times at night.
Old Jun 1, 2006 | 05:40 PM
DouBLeJ16's Avatar
That's not correct. You will run a better time if the tires & track are hot.. Normally when the track is hot, the air temp is hot also so that will bring the time up a little.
If your tires or the track is cold then you aren't going to get any traction..
Cold tires & a cold track = hard
Hot tires & a hot track = softer
Any car will launch better on a soft-warm surface then a solid-cold surface.
And the only reason people normally run better times at night is because the air temp is cooler.. That is the only reason.
Old Jun 2, 2006 | 09:56 PM
06SuperWhite_SoCal_tC's Avatar
Cooler Air Temp = Denser Air and More Power, puts it a little better. The cooler the air is the denser it gets = more air being cramed into the Engine.
Old Jun 2, 2006 | 10:00 PM
Neothin's Avatar
so in other words, 8pm is the best time to run, air has cooled off from teh daytime high and the track still is retaining most of its heat built up during the day.
akwdcaveman
Scion tC 2G Wheel & Tire
Jan 17, 2015 12:47 PM
lunchbx05
Dec 29, 2014 07:53 PM
darkshadowofxdeath
Dec 3, 2014 06:59 PM
ScionDP
Dec 3, 2014 02:05 AM
