2011 Scion tC short shifter pre-order from TWM Performance!
Introducing TWM Performance's Short Shifter for the 2011 Scion tC!
That’s right, it’s finally here! TWM Performance is proud to introduce our brand new short shifter for the 2011 Scion tC!
Here are the raw shifter specs:
- 30% throw reduction
- Relocated neutral for more natural driving position
- 0" height reduction
- Shifter CNC machined of solid steel
- Reverse lockout CNC machined of aircraft grade aluminum
- TIG welded for maximum durability
- Improved reverse lockout mechanism
- Available with base and cable bushings
- Compatible with the stock shift **** or a TWM weighted shift ****
- Lifetime warranty included
****TWM Performance Scion tC Video!!!****
http://www.youtube.com/watch?v=2DhFeX-Ea34
TWM Performance is proud to be the first company to design a quality short shifter for the 2011 Scion tC! The TWM Scion tC short shifter has a couple of cool and unique features that we’d like to talk briefly about; the first being the relocated position of the gears. As most of you have noticed, the stock shifter is awkward in its gear placing. Any rearward shift results in you pulling your arm into the drivers seat. So at TWM Performance we fixed this problem, and the shifter is now MUCH more enjoyable to use!
Furthermore, the stock tC shifter’s reverse lock mechanism leaves something to be desired. Made from thin plastic and having play throughout, it’s really something that Scion failed at designing. So once again, TWM came to the rescue. We engineered a aluminum RL mechanism that operates flawlessly with a system of bushings, springs, and dowel pins. The end result is a far more precise, solid and easy to operate shifter.
Finally this shifter comes with base bushings and is available with optional cable bushings and a weighted shift **** for the ultimate shifter overhaul available on the market for the 2011 Scion tC!
So here are a few comparison pictures, starting with the stock throw from 3rd to 4th gear, then the throw with the TWM short shifter installed.
Stock throw (3rd-4th)………………….and TWM Performance Throw
Pricing:
The regular retail price of the short shifter for the 2011 Scion tC is be $269.95, however we are offering a special pre-order price of $249.95! This pricing is a limited offer and will only last 3 weeks!
You can place your order at the following link:
TWM Performance 2011 Scion tC short shifter
All pre-orders will be scheduled to ship in the third week of March!
Please do not hesitate if you have any question regarding our brand new Scion short shifter or any of our other products! You can also call us directly at 1-877-655-0540 to place your order!
Thanks!
Patrick
Team TWM Performance
If you've got some spare time, check out our applications for the thousands of cars we carry!
-Shift *****
-Short shifters
-Bushings
-Shift boots
-Shift *****
-Short shifters
-Bushings
-Shift boots
Like us on Facebook for the most recent product sales and developments!
http://www.facebook.com/shortshifters
Check that your cable is properly installed I had mine on the outside when it goes on the inside. I had shifting issues fixed it and it's fine minus the dreaded second gear grind when it's cold.... Think it's a common problem with this transmission
Make sure there is plenty of grease on the shifter shaft where the reverse lockout lever goes up and down, and make sure the plastic bushing with the spring is properly installed, the RL operation should be very smooth.
Thanks,
Frank
Thanks,
Frank
BrokenTC2
Jan 27, 2015 03:32 AM
