General Tech and DIY Info for Any Scion
1NZ-FE CVT light weight flex plate?
Old Mar 22, 2021 | 12:41 PM
salmanghiyas's Avatar
Default 1NZ-FE CVT light weight flex plate?
Hello Community,
1: Can someone please share what is the weight of stock 1NZ-FE CVT Flex plate?
2: Can it be replaced by an aftermarket light weight one?
3: Which one? Any recommendations?
4: How much performance gain would be expected?
___
Old Mar 22, 2021 | 02:16 PM
Birsan's Avatar
Hi, the flywheel is like a controller, and observer for an engine. The need for this part was invented more than 200 years ago. The shape and his weight is calculated to eliminate to the gas engine the shaking movements. By having one flywheel little lighter than the OEM (Original Equipment Manufacturer), will make the car to have a bit of "shakiness" that will be transmitted to the engine mounts, then transmitted (and will be felt) by the entire car. I think that is safer to install a bit heavier than OEM flywheel. That will be better.
The round part in the left side of the picture is a flywheel. That part is designed to have the shape is such way to accommodate the one piston movement. Will give a better performance, by keeping the piston moving all the time (between the piston working needs).
Old Mar 22, 2021 | 10:53 PM
No offense bro but I was referring to branded aftermarket ones which are made and built as per OEM standards.
Old Mar 22, 2021 | 11:41 PM
MR_LUV's Avatar
Administrator
Administrator
Originally Posted by salmanghiyas
Hello Community,
1: Can someone please share what is the weight of stock 1NZ-FE CVT Flywheel?
No Offense but, you might get a better answer or reply IF You were to Identify Your Vehicle.
What Year, Model and Drive train is your Vehicle?
Administrator
__________________
Old Mar 22, 2021 | 11:58 PM
Administrator
__________________
Sir, with due respect I have posted my query in the general tech and DIY section considering my query as a generic one not specific to any specific model/year
Old Jul 15, 2021 | 10:30 AM
Low_Kei's Avatar
Then you won’t get an answer. FYI: No Scion products used a CVT. You either had a manual trans or a 4/5 speed automatic.
ColonelSanders85
9
Aug 8, 2009 12:18 PM
rub3414
18
Mar 25, 2008 05:10 AM
hotbox05
Nov 1, 2005 11:36 PM
ultrarev
Feb 20, 2005 08:29 PM
XTRMGMR
Feb 6, 2005 02:34 PM
