15,000 Mile Maintainence
Old May 13, 2004 | 10:33 PM
a330300's Avatar
Default 15,000 Mile Maintainence
I'm coming up on 15,000 miles, just wondering if people have been getting service done at their dealers, or finding an independent shop to do the work. Any suggestions?
Old May 13, 2004 | 10:48 PM
fr130's Avatar
You can go almost anywhere, I prefer dealer myself. These 15K interval services vary in price from dealer to dealer, so shop around. But if stuff needs to be replace i.e. brake pads, I would stick with OEM. I also would look for a dealer that will loan you a car fir free for your 15K inverval services.
Old May 14, 2004 | 02:38 AM
XBman's Avatar
yeah my moms Matrix had that done at our local dealer. They have her a rental car too! 15,000,30,000 50,000 up commin 65,000
Old May 14, 2004 | 05:02 AM
a330300's Avatar
Piercey wants $189.95 for the work for standard checks, filter replacements, fluids, etc , does this sound reasonable?
Old May 14, 2004 | 05:17 AM
XBman's Avatar
just fluids and filters? humm i get a 25 point inspection 2 with my moms car. But i guess its ok
Old May 14, 2004 | 06:09 AM
a330300's Avatar
5,000 MILE SERVICE
Recommended at 5K, 10K, 20K, 25K, 35K, 40K, 50K, 55K, 65K, 70K, 80K, etc., etc.)
* Change Engine Oil
* Change Engine Oil Filter
* Replace Engine Oil Drain Plug Gasket
* Set Idle Speed (where applicable)
* Functional Test of External Lights
* Retorque drive/propeller shaft flange bolts (where applicable)
* Rotate Tires
* Inspect Front & Rear Brake Linings
* Adjust Parking Brake
* Lubricate Chassis, Suspension, Propeller Shaft Points
* Inspect Battery and Clean Terminals as Needed
* Replace Rear Differential Oil (Sequoia, $24.95)
Fluids Inspected and Replenished
* Brake Master Cylinder
* Clutch Master Cylinder (manual trans.)
* Power Steering (if equipped)
* Transmission
* Battery
* Coolant
* Differential
* Transfer Case (4WD models)
* Windshield Washer
Visual Inspection Items
* Air Filter
* Check/Adjust Tire Pressure
* Drive Belts
* Hoses (cracking/damage/leaks)
* Shocks/Struts (Leaks)
* Windshield Wipers
* Chassis Nuts and Bolts
* Axle Boots (damage, leaks)
* Cooling System (leaks)
* Exhaust System/Muffler
* PCV Valve
* Tire Wear
* Steering Linkage, Ball Joints and Dust Covers
$ 69.95+tax
15,000 MILE SERVICE
(Recommended at 15K, 45K, 75K, 105K, etc... Includes all of the above)
* Replace Air Filter
* Set Timing (where applicable)
* Change Transmission Fluid (auto trans. only, T4 type trans. fluid add $27.89)
* Replace Differential Oil (where applicable, add $24.95)
* Replace Transfer Case Fluid (4WD RAV 4, add $43.95)
* Scope and Set Idle (where applicable)
* Replace Fuel Filter (carb. models only)
* Clean Throttle Body
$189.95+tax
30,000 MILE SERVICE
(Recommended at 30K, 60K, 90K, 120K, etc... Includes all of the above)
* Replace Non-Platinum Spark Plugs
* Drain and Refill Coolant
* Inspect fuel lines, connections, tank band & vapor vent system hoses
* Change Transmission Oil
* Change Differential Oil (2WD Models)
Old May 14, 2004 | 03:47 PM
George's Avatar
Default Re: 15,000 Mile Maintainence
Just ask them what they want to perform the service as published in the owner's manual.
Many dealers "pack" the bill by performing unneeded work like "engine flushes" and other such snake oil. Don't just say "Do the 15,000 mile service." as that gives them carte blanche to do whatever they deem to be their "15,000 mile service". Make sure that they are clear on the idea of "as published in the owner's manual".
An independent mechanic might be a good idea. Experienced dealer mechanics often move on to start their own shops where they can charge less and keep more of what you pay. Get recommendations from friends for good mechanics.
George
Old May 23, 2004 | 11:54 PM
tCtech's Avatar
getting a 15 K service is dumb. i do them everyday and they are totally worthless (to the customer)
your trans fluid is made to last a lot longer than 15,000. Pull out the dipstick, still bright red? then you're fine. don't need to pay for new stuff.
wipers: if they work well and aren't torn than you don't need new ones.
oil change, air filter, drum brake clean and adjust, tire rotate are all worthwhile. but you can easily do all that yourself as long as you own a jack with stands. most of your fludis probabaly arent low.
so basically, if you're mechanically inclined and not lazy you can pretty much take care of this sevice yourslef. if not, i'd say get it and forego the trans service and charge for it.
Dmmcclair
Aug 13, 2015 07:14 PM
D_Roke
Mar 31, 2015 05:37 PM
toyotaisme
Jan 10, 2015 10:24 PM
minter66
Dec 15, 2014 01:45 PM
