30k maintenance questions!
It's in your maintenance handbook.
Replace engine oil and oil filter1
❑ Rotate tires
❑ Replace engine air filter
❑ Replace spark plugs (xA and xB)3
❑ Tighten drive shaft bolt
❑ Inspect the following:
__ Ball joints and dust covers
__ Brake lines and hoses
__ Brake linings/drums and
brake pads/discs4
__ Drive shaft boots
__ Engine coolant
__ Exhaust pipes and mountings
__ Front differential oil
Additional Maintenance Items for Special Operating Conditions2
Driving in desert or on dirt roads:
❑ Tighten nuts and bolts on chassis
Driving while towing:
❑ Replace front differential oil5
❑ Replace manual transmission oil
Dealer Service Verification:
Date:
Mileage:
__ Fuel lines and connections, fuel
tank band and fuel tank vapor vent
system hoses
__ Fuel tank cap gasket
__ Radiator core and condenser
__ Steering gear box
__ Steering linkage and boots
__ Transmission fluid or oil
❑ Rotate tires
brake pads/discs4
__ Engine coolant
Date:
Mileage:
system hoses
Allright I kind of have this question too I had my brakes replace about 4k ag i have like 32k on my car i change my oil every thre e and always have them take care of other fluids not sure if my spark plugs have been changed. What should I have done cause a lot of that looks like stuff that I already have done.
xB plugs should be changed every 30k miles I believe. Unless your car has been driven under the special conditions listed above, you only need to do the stuff above the special conditions.
If you feel like spending the extra dough, I'm sure the dealership will be more than happy to give you a full inspection of the car (and will probably recommend one).
Plugs and fluids mostly...
FYI, when I was a service Writer I got a 10% bonus whenever I sold a 30 or 60 K service because they are such a money maker. Half the things they bill separately can be done while the tech is waiting for the oil to drain...
Yeah, I'm close to my 30k mark too, I'm going to change spark plugs, any suggestion on who makes good ones? Also, do you think it would be important to do that system cleaning thing Toyota has i.e. carberator cleaning, intake valves, combustion chambers, its that crap they have at the front desk...
Wouldn't bother doing any engine treatments at 30k. Modern gasoline has plenty of cleaners and additives that promote clean burning fuel. However, if you do want to use a fuel injector cleaner, I would recommend Chevron with Techron. It's about $6 at the auto parts store.
And personally, I'd go for OEM plugs to avoid any warranty issues.
bootlgr
Jan 26, 2016 01:22 AM
