30K miles Service
Old Feb 27, 2006 | 06:38 PM
agi_jw's Avatar
DeepSouth Scions
sIcKsCiOnS
DelMarVa
Default 30K miles Service
I need to get my 30K miles service soon.
I called my dealership and they said it will be $420!!!!!!!!! I am in FL.
How much does it cost you guys to get it done??
Old Feb 27, 2006 | 11:09 PM
Packy's Avatar
I'd get a good independent mechanic. For our Subaru Forester we were being quoted between $500 and $600, and most of it is just inspections!! I did as much as I could myself (oil, air filter, coolant, etc) and the total at our independent mechanic was a bit over $200. =)
Old Feb 27, 2006 | 11:51 PM
vintage42's Avatar
Default Re: 30K miles Service
I called my dealership and they said it will be $420...
The book says:
? Replace engine oil and oil filter
? Rotate tires
? Replace engine air filter
? Replace spark plugs
? Tighten drive shaft bolt
? Inspect the following:
__ Ball joints and dust covers
__ Brake lines and hoses
__ Brake linings/drums and brake pads/discs4
__ Drive shaft boots
__ Engine coolant
__ Exhaust pipes and mountings
__ Front differential oil
__ Transmission fluid or oil
An oil and filter change should be $20.
Rotating tires should be $20.
Replacing air filter should be $20.
Replacing spark plugs should be $20.
The rest is checking (looking to see if more work is needed).
When I get my xB, I am counting on taking it to the excellent import shop that has maintained my Mazda for the past 16 years, and letting them do the services and checks.
Old Feb 28, 2006 | 01:28 PM
agi_jw's Avatar
DeepSouth Scions
sIcKsCiOnS
DelMarVa
Don't they drain transmition fluids and steering fluids or whatever alse?
Sorry, not car person but i was thinking they change ALL the fluids ... not just oil.
Thank you all for your input
Agnes
Old Mar 1, 2006 | 05:10 AM
Townsend_xB's Avatar
30K maintence through Las Cruces Toyota is $274 for a four cylinder
Oil
Engine Filter
Spark plugs
Fuel injector service
Transmission service
Radiator Service
rotate and balance tires
brake inspection, cleaning and adjustment
battery service and load test
replace wiper inserts
replace air filter
lubricate key chassis parts
fill brake fluid
fill clutch cylinder
fill power steering fluid
fill differential
fill transefer case
fill washer fluid
inspect and clean cabin air filter
inspect colling system
inspect exhaust system/muffler
inspect PCV valve
inspect check and adjust tire pressure
inspect axle boots
inspect drive belts
inspect hoses
inspect shock absorbers and suspension
inspect tire wear.
I am sure not all of that applies to my car, but thats whats in the little handout I have. Hope that helps
Old Mar 12, 2006 | 01:39 AM
xAlex's Avatar
I got quoted around $340 for this service... it included an "engine flush" i have no clue what that is, can someone help me out here. I opted to not get it done at the time b/c i dont walk around w/ $400 in my pocket and i dont really know if it's necessary. I've only been doing the oil changes come to think of it and my car's nearing 30k, what do u think i should do?
Old Dec 18, 2007 | 06:27 PM
Silverstreak-tC's Avatar
This thread is pretty old but i would like to know wut plugs do you guys recommend me using to replace my denso on my 06 tc?? i was thinkin bout gettin NGK IX iridium
Dmmcclair
Aug 13, 2015 07:14 PM
kleecker
Mar 17, 2015 12:15 PM
TheTripleC
Jan 4, 2015 06:46 PM
vho
15
Feb 9, 2004 01:58 AM
BlueBox
22
Nov 7, 2003 08:18 PM
