Broken Right AC Knob - HELP!
Hey Guys and Gals-
Somehow when I installed my FM Modulator the righ AC **** got messed up. It doesn't really turn correctly and I can't get the air to go through the defrosters, etc. Is this something I can fix? The guys at the dealer in town want to charge me $95. Ouch.
Thanks!
Cody
Thanks!
Cody
Originally Posted by eugovector
That's what you get for using an FM modulator. Those things are evil.
I would check on where you mounted the FM Mod maybe it needs to be relocated because it might be putting stress on something in there. I would dounle check it and if you do need to relocate I would put it behind the radio. That's where I placed mine before I got a different radio with an AUX in.
Hope this helps,
You probably threw the cable out of adjustment. On some of the ***** it is attached to a cable sometimes that makes the vents move in different ways. You need to pop the cable out, turn the **** all the way to the left probably than put the cable back on and see if everything is fine.
BlingSlade
Oct 19, 2016 12:39 AM
