Don't Use the Factory Jack..Read This!!!
Old Jan 13, 2007 | 11:55 AM
losmorob's Avatar
I use ramps to change the oil. Just too low to get a jack under.
Hey, and it only took me 20 minutes to find the jack the first time!
Old Jan 13, 2007 | 02:31 PM
UBOW's Avatar
The first time I used my factory jack I got the front wheel 1 inch off the ground and the metal folded like it was made of lead! I took it back to the dealer and they still have yet to replace it (19 months). I'm thinking of getting an electric scissor jack. I have a 3-ton floor jack in the garage.
Factory floor jack is absolutely worthless!!!!!
Old Jan 13, 2007 | 02:53 PM
ROBs-xB's Avatar
yea they are worthless, no good
Old Jan 13, 2007 | 02:58 PM
ROBs-xB's Avatar
By the way... the roadside assistance guy that helped me get
my car up said that even on the flattest ground you can find
those jacks aren't any good and he doesn't recommend them
at all, he said that as you start putting it up, the car starts
slanting, the higher you go the bigger the slant, more likely
to fall back...
Call road side assistance, get them to change a spare for you,
one of the benefits of buying a new car, use it.
Old Jan 13, 2007 | 03:16 PM
Knoxbox's Avatar
No offense to anyone. But it's truly driver error and placement of the jack, I can see were it not greased could make it hard to crank and that's legit,
But correct placement of the jack is important and any slight movement on any jack could cause it to fall, jack stands are the way to go as terribleted said.
I work in an automotive shop from time to time and we've never had a vehicle fall, but we double and triple check jack location before proceeding.
__________________
Old Jan 13, 2007 | 03:43 PM
UBOW's Avatar
Originally Posted by Knoxbox
no offense to anyone... but its truely driver error and placement of the jack, i can see were it not greased could make it hard to crank
I followed jack instructions to the letter. It still bent like butter. Also, the jack came lubed from the factory. I've been jacking cars for nearly 45 years - you think I haven't done this before? Go away. I found your response offensive. Sorry, I have to say it straight up.
Old Jan 13, 2007 | 03:50 PM
Knoxbox's Avatar
Go away... lol... now thats down right rude, and your making an ___ of urself, i never once stated that you hadn't jacked up a car or anything of the nature. its sad when you read something and get all out of whack cause you feel someone is picking on you. 45 years so this makes you what at least 55 - 60 u'd think u'd have done a little growing up in those years I'm only 23 and I have a little more tact than to tell someone to go away and take offense to something that really wasn't that offensive, sure maybe your jack is defective read all the post not everyone's was greased from the factory... that was their problem... and not everyone has had problems so maybe yours was defective.. but then again, whats the likelihood, 45 years of jacking up cars maybe u subconsciously thought u put it in the right location and u were wrong. people make mistakes.
^^^Just thought I'd give you some true criticism... now if u want to get mad and tell me to leave u have all the right.
LOL have to love stupid people.
I, myself can truly say I've used a factory jack maybe a handful of times... i surely wouldn't use one for car work unless it was emergency on the side of the road and had nothing else to use.
But then again that just makes common sense, but when I buy aftermarket wheels all of that gets removed and replaced with a can of fix-a-flat and if that can't be used call a tow truck.
Oh and u'd think 45 years of jacking up cars u'd have a jack of ur own and wouldn't use the factory jack.
Something else I just noticed, my first message wasn't even directed at you or anyone else it was generalized... wow... learn to read, and stop reading into things.
__________________
Old Jan 13, 2007 | 04:57 PM
losmorob's Avatar
This "old fart" is
Old Jan 13, 2007 | 09:11 PM
Knoxbox's Avatar
Originally Posted by losmorob
This "old fart" is
least someone knew i wasn't serious in that last post ;)
Old Jan 14, 2007 | 09:16 PM
Big_Bird's Avatar
I only use the stock jack to initially jack up the box, it's too low for a hydro jack to slip under there, then i use the hydro jack and then put the jack stands under there. Works well for the 30 seconds i ever use mine.
and yes, dont ever do any work using only a stock scissor jack unless it is an absolute emergency with no other avenues to choose from.
Old Jan 14, 2007 | 09:21 PM
burstaneurysm's Avatar
I used mine yesterday (after I finally found it) to get jack stands under. Aside from stock jacks being annoying to use, mine performed as it should. Mine's an 06.5 so I don't know if anything changed as far as the jack...
Old Jan 14, 2007 | 09:44 PM
Knoxbox's Avatar
okay... i gotta ask this sorta a thread jack but just for a sec, were is everyone getting their cool cartoon avatars... i seen them alot.. i'll do a search so im not a no0b like the rest haha.. send me a pm if u wanna help me out haha.
Old Jan 14, 2007 | 10:16 PM
Big_Bird's Avatar
^^pm'd ya
Old Jan 14, 2007 | 10:17 PM
Knoxbox's Avatar
much thanks man
Old Jan 14, 2007 | 10:32 PM
Yea, the avatar creator was in OT... it's pretty cool, although there aren't noses... and the export feature doesn't really work.
Old Jan 14, 2007 | 11:48 PM
xBster's Avatar
I use the factory jack for emergencies and maybe a quick brake pad check, but never when I am going to be under the car...floor jack and jack stands for me
Old Jan 15, 2007 | 03:31 AM
Guamsilverbox671's Avatar
Right on.
And BTW, Please use the jack stand when working on your cars. The emergency jack ws never designed for that.
Old Jan 15, 2007 | 04:42 AM
outrage36862's Avatar
Default :)
I've used my jack 2 times in the last 3 days and haven't had any problems. Just be careful and make sure its lvl.
Old Jan 15, 2007 | 02:12 PM
HeathenBrewing's Avatar
Originally Posted by TerribleTed
I HOPE you guys talking about using the factory jack for doing repair, maintenance, and mod work are only using it to VERY CAREFULLY lift the car and then ......as the original poster found out he needed too....placing JACK STANDS under strong points to support the car while the work is being done. Place the jack stands at suspension mounting spots or jack points if available, then let the car down with the jack till most (if not all) of the weight is on the stand (or stands) not on the jack. To do anything other than this and go under the car is a death wish......yeah ok you can get away with it 95 times out of 100 but what about those other 5 times. If you use the factory jack for maintenance you are playing russian roulette.
I am a professional and work on cars all the time. I normally use jack stands, but there are times (emergency situations) where I have done things without stands. I have seen 5 cars fall from being lifted in my 33 years of messing with cars. 3 of these times I was working on the car. One of those I had a brake sieze up in my inlaws driveway the factory jack shifted and gave way and down it came...just barely got my foot out from under it before it hit the ground. another was also slight movement of the car while changing a flat (car was ebraked and in gear) factory sissors jack went sideways. 3rd time the cars front end was on jack stands and idiot buddy put the rear wheel drive car in gear running and drove forward tipping over and crushing the stands...he also put a small dent on my garage wall....good thing he stopped my TV and family room are on the other side. The other 2 times were car buddies doing repair/mod type stuff using factory type jacks. I have never seen a car fall off jack stands (forgiving powering the car off the stands with 1st gear) or off a large pad floor jack. (5-6 inch pad is best....the ones with only the 2 inch or so lifting point arent worth buying...they slip off things too easy). I knew 2 mechanics here in Atlanta that injured themselves by disregarding the use of stands...1 a broken leg the other a fatal injury. DO NOT GET UNDER A CAR WITHOUT STANDS OR A LIFT!!
The factory jack is only designed to lift the car to change a tire in an emergency and thats it. It is not designed to hold the car aloft for any kind of maintenance....the base is too narrow and the design to weak to take much movement. When you must use the factory jack certainly set the ebrake, put trans in park (automatic)or in gear (standard), be absolutely sure that the area is level and that the spot where the jack is going to touch the ground is asphalt or concrete not gravel or dirt. Be sure to lift the car only enough to enable removing the flat tire and no more (these jacks get less stable as you jack higher). Keeping you body completely out from under the car at all times change the tire.
For other than tire changing get a real jack. If you must use the factory instead of a real jack at least get a pair of jackstands. Scions are not that heavy, a basic pair of $20-30 regular duty stands is all you need (in fact alot of the "heavy duty" stands are yes a bit heavier but also taller...and taller can be a pain with cars as low as ours). Money well spent and hella cheaper than the costs of a injury.
100% spot on!
Been seeing a lot of ignorant posts recently (asking questions that are covered in the manual, going under a car with no jack stands, etc) but I am glad to see there are a few good posters left on this site.
Old Aug 22, 2019 | 08:18 AM
MR_LUV's Avatar
Administrator
Administrator
Thumbs up
danny662boy
Jun 12, 2009 08:47 PM
virgin
Jul 13, 2007 08:00 PM
tcva
Dec 8, 2006 12:50 PM
Rob_Tampa
Nov 10, 2006 07:30 PM
jct
9
Nov 26, 2004 06:27 PM
