HELP!: Cold-air intake problem, "check engine" ...
Old Nov 15, 2004 | 07:54 AM
gojann's Avatar
Default HELP!: Cold-air intake problem, "check engine" ...
Hi guys.. me and my friend are trying to install a cold air intake for my scion xA, but after installing it, "CHECK ENGINE" light appears.. engine seems to be choking, and the car limit me to rev up to 28000 rpm.. we put back the stock intake, but the problem is still there... can anyone help me? pls e-mail me @ gojan_22@yahoo.com. thanks..
Old Nov 15, 2004 | 08:03 AM
squirrel's Avatar
Disconnect the negative terminal from the battery for a few minutes. Then, start the engine and let it IDLE for 15 minutes. Everything should be reset and back to normal.
Old Nov 15, 2004 | 08:04 AM
squirrel's Avatar
Is it an Injen CAI?
I've installed at least 12 of them w/ no problems.
Old Nov 15, 2004 | 02:47 PM
gojann's Avatar
1. we only run it for 5 minutes, nothing happens.. does it need to be 15 minutes?
2. yeah, it's a Injen CAI.. do you heard problems with Injens?
thanks..
Old Nov 15, 2004 | 02:51 PM
mikochu's Avatar
I installed the Injen CAI. After the install, I started the car and threw a CEL (Check Engine Light). I turned off the car and unplugged the EFI fuse instead of taking the negative battery terminal off... I left it out for about 30 seconds. I plugged it back in, turned on the car and haven't thrown a CEL since...
Here's a tutorial on how to reset the ECU via the EFI fuse:
https://www.scionlife.com/forums/viewtopic.php?t=33062
Old Nov 15, 2004 | 03:24 PM
squirrel's Avatar
thanks..
I have never had problems w/ Injen intakes. That's why I always recommend them.
Mikochu's fix is a good also, as it does not clear out your radio settings and trip odometer.
Old Nov 15, 2004 | 03:28 PM
dgHotLava's Avatar
also, make sure you did not get the air-flow sensor dirty.
Old Nov 15, 2004 | 03:55 PM
ScionSniper's Avatar
Or damage it in anyway when you installed it in the in intake.
Old Nov 15, 2004 | 07:39 PM
gojann's Avatar
ok, i'm gonna try it tomorrow.. thanks for the advice.. so, that "choking" sound, is that gonna go away after i do that? the idle is going 1000 and 2000 rpm, up and down, is that the ECU doing it? i'm might think that there's some kind of leak or leakage of air somewhere..
Old Nov 15, 2004 | 08:12 PM
G-NIZZLE's Avatar
pm me i have a code reader and can help you out ...
Old Nov 16, 2004 | 06:06 PM
gojann's Avatar
hi.. i tried to remove the EFI fuse this morning.. still didn't work.. pls help me out..
Old Nov 16, 2004 | 11:37 PM
mikochu's Avatar
Continue conversation here:
https://www.scionlife.com/forums/viewtopic.php?t=34926
locked.
hampton1100
May 28, 2015 07:32 AM
xxmanrd92xx
11
Feb 4, 2015 01:40 AM
hotroddelux
Dec 3, 2014 11:33 PM
Strader
25
Jul 22, 2004 09:27 PM
Docsnuff
9
Nov 23, 2003 09:50 PM
