Oil?
Did a search but, as is often the problem, I came up with too many results to trudge through.
First question: What is Toyota Oil?
Second question: What is everyone using for oil and filters?
I'm coming up on my first oil change and need to know what is the best way to go.
I like the bosch filter for my and my wife's xB. The filter is well made. For oil I use mobil 1. It is high quality synthetic (many companies recomend it as oem) and you can get it EVERYWHERE.
i use M1 synthetic oil + filter also... but i think starting on my next change i'm going to switch to a K+N filter. they have that really nice nut on the bottom of the filter that makes taking the filter off really easy.
Just changed my oil for the first time... since my dealer will be changing it again in about 2000 miles anyway, I bought the $1.68/qt Discount Auto Parts 5w20 oil. If you're just buying dino oil, it doesn't really matter what you get. It's only once you get to the synthetics that you start getting actual choices that mean something.
I did, however, use the Toyota filter. They wanted $7 for one! I just bought two... because they had a special... 2 for $10.
Music City Scions
Originally Posted by Andrew1782
Use Mobil1 and Toyota filter.
Castrol Syntec and a bosch filters / I had a 96 impala ss and ran synter in it and never had ant engine problems when i sold the car had 189thousand miles on it. The guy that bought it from me said hes still hasnt had any engine problems with the car hes still runnin syntec so i strong believe in syntec motor oil if u want ur toaster to keep on runnin good for a long time
Not sure why people are advising you to use any weight but the recommended 5-30. That is what should be used. Lots of threads out there on this issue. Most agree the Toyota filter is the way to go.
crimson_sinn
Sep 25, 2015 09:41 PM
Klashan
Sep 24, 2015 12:39 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
