Problem solved
Old May 5, 2005 | 01:12 AM
User_S_13's Avatar
Default Problem solved
Turned out to be the AM-2 fuse in the engine bay that controls starter, airbag and other stuff. Just saved myself some expenses at the dealer.
Old May 5, 2005 | 01:28 AM
crayonBOX's Avatar
hmm, starter kill realy? connections to the igntion wires... maybe a bad alarm; does it arm?
Old May 5, 2005 | 01:30 AM
User_S_13's Avatar
How can I check the starter relay with a voltmeter?
The alarm was working and now isn't.....The aftermarket alarm power was tied in with the ignition switch harness power (white/blue)....perhaps the ignition switch is bad?
Old May 5, 2005 | 07:08 AM
M-Flo's Avatar
Check the fuses? Could be a blown starter fuse or some other electrical thingy-ma-jig.
Old May 5, 2005 | 09:19 AM
xBino's Avatar
make that warranty work for you and have it towed to the dealer
Old May 5, 2005 | 12:27 PM
violent_b's Avatar
does the starter try to start? or is there no noise at all? most car alarm (99%) starter kill relays are wired normally closed so that if there is a power problem with the alarm it won't disable your starter. since your warning lights are coming on I would say the ignition switch should be ok. I would check the starter kill relay of the alarm, maybe something came loose when you were moving it?
Old May 5, 2005 | 03:13 PM
User_S_13's Avatar
The alarm power wire was getting it's constant 12 v off the red/white wire....I moved it to another power source and it works now.....so I need to find out where the red/white wire gets its power from???
Old May 5, 2005 | 03:21 PM
Joehnn's Avatar
Good job solving your immediate problem.
Tell us if you find out more, it could help someone else down the road.
Old May 5, 2005 | 03:23 PM
User_S_13's Avatar
still can't start car.......
need to see if the starter relay is bad or the ignition switch...but when I turn the key from lock to on to acc everything works fine...go to start position and nothing.....
what could it be??
Old May 5, 2005 | 03:29 PM
couped's Avatar
Automatic not in park?
Bad clutch switch on a manual?
Old May 5, 2005 | 03:30 PM
Joehnn's Avatar
what could it be??
Sorry, I thought you had solved it. I don't have any experience with alarm systems.
I would guess that since it worked and then quit, its a fuse or relay, but thats a wild a@# guess. C'mon guys give this man some expert help.
Old May 5, 2005 | 03:36 PM
User_S_13's Avatar
the alarms starter kill feature is not installed
Old May 5, 2005 | 03:53 PM
engifineer's Avatar
Check the park/neutral switch if it is an auto.
RayScionXB
Regional - Pacific South
19
Mar 5, 2015 08:22 PM
RayScionXB
Regional - Everywhere Else
Mar 3, 2015 08:27 PM
evolving_machine
Feb 27, 2015 09:53 PM
UltraCronic
Feb 11, 2015 06:55 PM
Inazuma
14
Apr 6, 2004 06:29 AM
