quick detailing question
Old Apr 17, 2007 | 04:40 PM
s44life's Avatar
Default quick detailing question
So I'm planning on detailing the car this weekend, cuz it's supposed to be 60 degrees yaaaaay.
I'm going to do clay kit, wax and scratch removing.
My question is, in what order should I be doing this???
From what I understand, the clay kit removes surface contaminants so I would do the scratch remover after the clay kit because it fills up the little blemishes in the clear coat. Then finish it up with wax.
Is this correct?
Old Apr 17, 2007 | 05:14 PM
KINGxOFxSKA's Avatar
Unique Scionikz
You would want to wash your car first.
Then use the clay bar.
Then Scratch Remover, Glaze, or Paint Cleaner
And then finish with a wax.
So yeah you had it correct. :D
Old Apr 17, 2007 | 05:16 PM
1nicescion's Avatar
clay kits work great, if.............you use them correctly. first wash the car well no need to dry it just make sure the crap is all off of it.
1. keep the car lubricated in the area you are working in. clay kits come with a spray wax type lube. if you run out any spray detailer will work.
2. dont let that part of the car dry out. it will leave marks that are a real pain to remove.
3. run in the same direction with the clay until the resistance is no more. the surface will feel smooth as silk once done. keep needing the clay and switching sides. alos periodically check for dirt in the clay itself and pick em out
scratch remover, (3m perfect it is a great product or 3m rubbing compound same thing, different dept in the store). use the scratch remover before waxing the car. this too should also be done out of direct sunlight. i live in NY and sunlight here is like seeing the lochness monster. you know its out there but you never see it, only hear about it from time to time.
youll want to rub it lightly as this will leave a spot in the finish that you can see in the sunlight. ever look at a black car thats been buffed with scratch remover? and how many waves swirls etc are in the finish. using it by hand not so much but with a machine you have to have skills.
finish up with your best car wax. all car was really does is seal in what you have just finished. some work better then others whichever you find the best will work.
so we have wash, clay,scratch remover, wax! lets see pic before and after! good luck!
Old Apr 17, 2007 | 07:32 PM
s44life's Avatar
yeah thanks guyz.
I forgot to mention the wash, but it's planned. It's just so common sense and I didn't think I would have to mention it.
Products I'm using are:
Meguiars Deep Crystal Car Wash
Meguiars Smooth Surface Clay Bar Kit
Toyota Scratch Remover
Meguiars Tech Wax
Thanx for the input guyz, ur help is appreciated
Old Apr 18, 2007 | 02:12 AM
frostyblizz's Avatar
If you really want to get into the details of detailing go to http://www.autopia.org. Detailing your car can become very addicting!! This website is awesome, lots of info on products, techniques, tips etc... you can learn forever.
Old Apr 18, 2007 | 03:13 AM
brian's Avatar
autopia is the best resource i've seen.
Old Apr 18, 2007 | 03:15 AM
paul34's Avatar
yay +1 for autopia
glad to see other autopians here.
Old Apr 18, 2007 | 06:25 AM
taktics's Avatar
jus a suggestion this is what I do for mu car jus throwin it out there but I use the turtle wax ice soap with a microtech mitt I think that's the name but washs it bomb then I use the matching stuff but the spray on detailer wit the microtech cloth comes out gud u won't be dissapointed then for the windows BELIEVE ME WHEN I SAY THIS but.... rubbing alchohol works the best om windows no streaks watsoever and its cheap like 49cents for a bottle soo that's my secret but that's me
Old Apr 18, 2007 | 04:33 PM
1nicescion's Avatar
what he said ^^^^^^ microfiber towels are the way to wash and dry. sponges suck!
Old Apr 26, 2007 | 01:12 AM
hawgs74's Avatar
nice info
Old May 1, 2007 | 09:30 AM
bB2NER's Avatar
Music City Scions
Originally Posted by s44life
yeah thanks guyz.
Meguiars Tech Wax
Instead of the Toyota scratch remover I'd use Scratch X and only on the areas needing work. For wax I'd recomend Eagle One Nano wax. Scion paint loves this stuff and gives great results.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
ShadowMage
16
Jul 25, 2004 06:02 PM
