Touch up Paint Recommendation?
Hey everyone, Fall is coming, and soon to be winter. My car was badly chipped from summer work roads (every route i could think of to get to work was on construction)
I need a recommendation on where to get touch up paint, kits, etc and how would i approach on touching up my hood, doors
Thanx in advance, and i hope everyone else who needs to touch up , do so before the winter salting comes as well
the dealer has bottles of the color you need.. i had to do this after some A-Hole door dinged my car.. i used a tooth pic to apply it because the brush was way to much for the area i needed.. then i went over it with a clear nail polish and then buffed it out and you can barley tell.. also 3m makes a good rubbing compound that you can try depending on how big the chip is.. i used it on my hood.. its not cheap though its like 35 bucks a bottle and i got it at napa autoparts.. hope this helps
does the dealer also have the clearcoat and primer as well?
i can just go to the parts department at the dealer correct?
tooth pick sounds like a good idea, i got plenty of dings that a tooth pick would defintly be better than using a brush
thanx for the tip
thanx for the tip
http://www.touchup123.com/
i saw a couple of people recommending this on autopia.org
but i've yet to try it. i figure i'll try it before i trade/sell my car in a few years. i will need it by then anyways
i'll check that out, but like i said, if you are gettin snow around your area, and you have chips, mind as well get a touch up paint kit now and patch some of those spots. I got some spots that can see metal since winter was over. I need to cover them up incase they rust up this winter.
god i hate flying rocks!
Ferretgrrl
Oct 15, 2018 02:50 AM
my06tc
Jun 25, 2015 12:18 AM
wesley_t
Dec 18, 2014 06:59 AM
