weird tire pressure question...
Old Apr 22, 2007 | 01:37 AM
jct's Avatar
jct
Default weird tire pressure question...
went to check the air pressure in my tires
and all of 'em were around 37psi!!!
i have not drivin my car for at least a good 36 hours
i haven't checked my pressure for at least a good 2.5 months
haven't added any air with in those months either
question is how did my air pressure rise with out adding air?
Old Apr 22, 2007 | 04:25 AM
Metro273's Avatar
Air in tires increase due to warm or hot ambient temperatures outside.
Old Apr 22, 2007 | 02:04 PM
jct's Avatar
jct
well i checked it this morning and its where i left it off yesterday
Old Apr 22, 2007 | 02:18 PM
Vincenzo's Avatar
My tC does that. I always put 35psi in all tires, then reset the tire pressure indicator. I checked the pressure of one tire and it was past 40psi after a week of driving (the weather has been moderate to cool). One tire though I believe has a slow leak, it frequently goes below 20psi and throws up the tire pressure indicator. Everytime the indicator comes on and I check, that one is low but another tire has higher than normal pressure. So far I'm running the stock Yokohama's and hope to replace them with BFGoodrich g-Force Sport's later this month.
Old Apr 22, 2007 | 02:41 PM
Jan06xB's Avatar
Could it be that you are putting air in from a high pressure air supply and when the pressure drops it cools the air in the tires that later warms up and increases the pressure even more? SO you are actually measuring the pressure in the tire when the air in the tire is really colder than outside temps and when they warm up they increase. Also Since the outside air has increased a bit recently - if you were pumping them up in 30 degree temps and now it is 60+ degrees that also will make them increase in pressure.
Old Apr 22, 2007 | 02:46 PM
Vincenzo's Avatar
Thanks Jan.. I'll lessen how much pressure I put in when I fill up next time, probably 25psi and recheck their pressure later in the day. Good info.
Old Apr 22, 2007 | 10:32 PM
jct's Avatar
jct
i also kind of thought if the barometic pressure messes with out tire pressure idk
Old Apr 22, 2007 | 11:13 PM
Jan06xB's Avatar
Barometric presure is only a inche out of 30 so it really doesn't matter that much. More temperature than anything thing else But I would not start at 25 cold. You are better off a little higher than lower at all - will save gas and when you have to corner hard it will handle the loads better.
Old May 1, 2007 | 09:03 AM
bB2NER's Avatar
Music City Scions
When tires pressures are set during cold weather they will rise as the outside temps do. The same way pressures go down after summers over. Happens every year. My guess is that you had them set around 32 during cold weather. Right?
Besides 37 psi is about right for high mpgs. during the summer season anyways.
Sooby
Scion tC 1G Wheel & Tire
11
Apr 8, 2020 11:51 PM
kingofthecrate
Jan 21, 2015 09:28 PM
JDMxB
23
Feb 26, 2004 06:16 AM
Strader
Oct 12, 2003 11:46 PM
