tC: COMPLETE: Dezod s1 TURBO KIT plus many extras!!!
Sold my tc, so now I'm selling my turbo kit. Not parting out because this is a 100% complete kit with the necessary extras. Every last clamp/coupler/vaccum line/...etc. EVERYTHING is included. That being said, all you will need is new oil, exhaust manifold gasket, copper rtv for the oil pan gasket and I would get new spark plugs (but I will include a set of step colder plugs anyway).
Asking $2500. I will ship the kit for free.
Fits 07-10 tc's. (to fit the 05-06, you will need a new wiring harness & intake pipe)
The turbo kit is the Dezod S1. Everything works and is in good condition. roughly 10k miles on all components.
Included is the following:
57 trim Garrett Turbo
Dezod s1 turbo manifold
Synapse engineering BOV
Synapse engineering BOV anti-stall kit (much louder and helps with tuning)
Synapse engineering wastegate (comes with extra spring) currently at 9lbs
Dezod catless downpipe & s-pipe (w/ a second bung for AFR gauge sensor)
Dezod front mount intercooler/piping/couplers/clamps/brackets
Deatschwerks 700cc injectors
Walbro 255 fuel pump
NGK step colder spark plugs (recommend new ones however)
Tapped oil pan w/ braided steel feed & return lines
Blox vaccum block & all needed vacuum lines
Dr isotope radiator cooling plate
Turbo heat shield (cover)
A-Pillar 3 gauge pod
AEM digital boost gauge & sensor
AEM digital oil pressure gauge & sensor
AEM digital air/fuel ratio gauge & sensor
(gauges come with both the black & white faceplates, & the silver and black bezels)-the gauges alone were almost a grand brand new
ACT 6 puck clutch kit (clutch/clutch disc/alignment tool/throwout bearing)
AEM FIC and harness for 07-10 tC's (harness has resistor mod completed)
(Fic comes with tune for 9lbs boost but will need a retune immediately, I also will include the base calibration tune)
Most parts will come in original boxes and come with original manuals.
I will also send install instructions, or you may find them online.
Everything you could want or need is here. Install took me and a friend 1 day to complete without much prior knowledge. This kit is basically brand new...like I said, less than 10k miles on all components. My loss = your gain.
Joyride
27
Nov 16, 2010 11:51 PM
