tC: Fully Built Engine
Im selling my fully built race engine never installed or ran. 2005 Scion TC 2azfe. I got one hell of deal on a FRS so now im building that one. Below is my facebook link to some of the build pics. Everything that is in the engine is brand new. Nothing used. Motor was built to all specs. Used proper torque and tools. THe head and block has a max rating of 50psi. I was looking to push 790hp on e85 38psi with this build.
Darton Sleeved block with block honed to pistons
BC valves and springs,
BC cams,
5 angle valve job,
PC block and HEad
PC Lower Crank case,
PC Oil pan,
PC Timing side cover,
PC Valve cover,
PC Gato Intake manifold,
Brinks Stainless Tubular Turbo Manifold,
GATO Fuel Rail,
K1 Rods,
Wiseco Pistons with rings filed,
Machined Crankshaft,
ACL main & rods bears,
ACL Thrust Washers,
Felpro Upper & Lower Gasket Kit.
PC water pump,
OBX light weight underdrive pulleys,
OBX coil packs,
NGK colder plugs,
Balance Shaft delete,
cosmetic head gasket,
New Timing kit with Guides
New Oil pump assembly
ARP head bolts,
ARP Rod bolts,
ARP crank cap bolts,
Im sure i missed a few parts that are in there.
Text David 5752192876 asking $5000k or best offer.. I have well over $9000 in this build
more pictures can be found on my facebook link below
IF YOU CLICK THE BELOW LINK AND IT COMES UP WITH AN ERROR. ON THE PAGE THAT POPS UP CLICK ALBUMS AND SEE IF YOU CAN VIEW IT THAT WAY.
https://www.facebook.com/tigerboy14/...5820464&type=1
BC cams,
5 angle valve job,
PC block and HEad
PC Oil pan,
PC Valve cover,
GATO Fuel Rail,
K1 Rods,
ACL Thrust Washers,
PC water pump,
OBX coil packs,
NGK colder plugs,
ARP head bolts,
ARP Rod bolts,
I do like that it's all pink though lol. If you're going to paint the whole thing and want people to talk about it / notice you, why not paint it all a bright pink lol.
Good luck with the FR-S build!
Phillip_Injen
53
Jan 17, 2004 01:56 AM
