turbos, exhaust, intakes
tC: Scion tC Turbo Kit parts manifold downpipe boost gauge blow off valve headlights
Old Oct 8, 2013 | 02:18 PM
guitarguru44's Avatar
Default Scion tC Turbo Kit parts manifold downpipe boost gauge blow off valve headlights
Hello I sold my 2006 turbo Scion tC and have some parts left over. Most of these parts are banged up but you might want to score a bunch of stuff at a low price. The kit that I had on my car was the Dezod kit which is listed below:
Dezod S1 Turbo System, Kit capable of 400 hp
Genuine Turbonetics T3/T04E 50 trim .63 a/r turbocharger
Stainless steel braided -4 AN oil feed line
Stainless steel braided machine crimped -10AN oil return line
Tapped Oil Pan System
Stainless steel TIG welded turbo manifold (1/2” thick head flange)
Tial 40mm wastegate (multiple boost level capable)
Stainless steel 2.5” downpipe
Stainless steel 2.5” s-pipe
HKS SSQV blow off valve
Front mount intercooler 26”x 6.5” x 3.5”
Mandrel bent, light weight, SFP Technology aluminum intercooler pipes
2.5” aluminum intake system with DSS Technology MAF housing
AEM dry flow filter
4 ply silicone couplers
T-bolt clamps
Turbo install kit
CNC vacuum manifold
Plug-N-Play 550cc fuel injectors (no cutting or splicing)
AEM Fuel & Ignition Controller (AEM FIC) w/ Base Calibration
Custom wiring harness for the AEM FIC (no cutting or splicing)
Custom open dump tube
The winning bidder does not get the full kit as that was on the car when I sold it. The winning bidder gets a bunch of stuff that is left over from that kit as well as some additional stuff, which is listed below.
1 Manifold (little crack)
2 Downpipes, one open and one closed dump (both with cracks)
1 Stock oil pan (I hammered this off of the car so there is a crack in it)
3 Quarts Royal Purple synthetic manual transmission fluid
4 NGK bkr7eix-11 spark plugs (gapped to 0.02
1 Dezod hardware kit (D06-0205001)
1 Stock clutch (used)
1 Act clutch (used)
1 Set of stock springs
2 Recharger kits for the turbo air filter
1 HKS SSQV blow off valve (pin broke off and needs to be attached)
1 AEM Boost Gauge (won't power on)
1 Turbo shield housing
1 Set stock spark plugs
1 Set stock injectors
1 Set of custom painted white headlights
There probably is some other stuff that I am forgetting to list, but if you see it in the picture you will get it. If I find out there was some stuff that I forgot to list I will throw that in when you come to pick it up. I will not be shipping this lot. This is for local pickup only and no part outs. Just trying to get rid of all of this at once. You obviously don't have to take everything with you but you may as well take it all and sell off what you don't want. There's still a bunch of good expensive stuff in here.
Here's a link to the ebay auction. If you are interested please put in a bid through there. Thanks!
http://www.ebay.com/itm/261302976728
Old Oct 11, 2013 | 03:46 PM
4 days left and so far all of this will sell for $5.50. Looks like someone may score a great deal on a bunch of stuff.
Old Oct 13, 2013 | 06:38 PM
Less than 2 days left and only at $20.
Old Oct 14, 2013 | 11:11 PM
This all will be sold to the high bidder within the next 15 hours. Still only $20, good luck to all bidding.
Old Oct 15, 2013 | 01:23 PM
40 minutes left.
Old Oct 24, 2013 | 03:33 AM
tCTRICE10's Avatar
Do you have any parts left ?
Old Oct 29, 2013 | 08:45 PM
No, sorry. Sold it all for $53.
Old Nov 3, 2013 | 04:02 AM
bushdog's Avatar
whoever got this...WOW! did you end up having local pickup or shipping?
cessblood
Sep 15, 2015 06:50 AM
greytc
Jan 12, 2015 09:49 PM
amart
Scion xD Aero & Exterior
Dec 23, 2014 12:06 PM
ScionLife Editor
Nov 25, 2014 03:00 PM
eric_m
79
Mar 17, 2013 12:21 AM
