FS TC: SPC 2° CONTROL ARM
This is what I have from when I took off my coilovers today. The link is below to the website. Used for lowered cars. Only used for 10k miles. 120 shipped OBO.
http://www.spcperformance.com/PROD_D...d2=67485&cmd3=
This fixed change arm is ideal for correcting excessive negative camber issues seen in lowered Scion tC's. The Scion tC comes from the factory with a cam bolt that provides +/- 1.25 deg. This factory change is not enough for lowered vehicles. By increasing the length of the rear upper control arm SPC Performance adds 2 deg. positive camber to the rear suspension that can then be dialed in with the OEM cam bolt.
Rear Adjustment range: (Includes the camber adjustment built-in from the factory) Camber -3.25 degree to +3.25 degree
Installation time: .5 hr/side
Required: 1 per wheel
Applications
Scion: 2005 & Up tC
I believe SPC sells them for 99.95 an arm.
Applications
Scion: 2005 & Up tC
"By increasing the length of the rear upper control arm SPC Performance adds 2 deg. positive camber to the rear suspension that can then be dialed in with the OEM cam bolt."
