Rotora Big Brake Kit: Scion xA / xB 2004 2005 2006
Old Mar 22, 2011 | 11:57 PM
1fastscion's Avatar
Default Rotora Big Brake Kit: Scion xA / xB 2004 2005 2006
Attention SL Members:
FastScions.com is currently clearing out old inventory. We are selling a BRAND NEW Rotora Front Big Brake Kit for the Scion xA / xB 2004 2005 2006 PN RBK042.01. Included in the Kit are 13" Slotted 2-Piece Rotors, 4-Piston Red Calipers, SS Braided Brake Lines, H2 Ceramic Pads, CNC Brackets, Hardware, Etc.
This Kit RETAILS for $1595, we have it ADVERTISED on our website for $1375. Right now SL MEMBERS CAN PURCHASE for $700 with FREE SHIPPING. Please call or email for further information or to purchase. This is the only kit we have left!!
ROTORA 4-PISTON BIG BRAKE KIT
Fits: Scion xA / xB 2004 - 2006 (Must have 17" or Larger Wheels)
Part Number: RBK042.01
Rotora 4-Piston Front Big Brake Kit for the 2004 2005 2006 Scion xA / xB
SLOTTED ROTORS, RED CALIPERS
Made of billet aluminum alloy and CNC machined to ensure the highest quality; Rotora's high performance brake system for the Scion xA xB enables superior brake modulation while improving overall pedal feel to ensure equal distribution of weight transfer when braking. To achieve this proportional front-to-rear brake bias, Rotoras opposing piston calipers are fine tuned by increasing the clamp load to the optimal level while utilizing the stock master cylinder to retain overall front-to-rear brake bias. Rotoras full big brake system design delivers excellent initial bite, exceptional modulation, and consistent pedal feel for street and track use applications. All systems are ABS compatible and direct bolt on replacement with minimal modifications required.
COMPONENTS/FEATURES:
-Rotora billet aluminum alloy 4-piston racing calipers with sequentially sized piston bore sizes engineered to each specific vehicle.
-Rotora billet aluminum hat with “floating” disc assembly to reduce heat related stress and unsprung weight.
-Rotora 330X30mm 2-piece heat treated directional vane disc system to improve airflow/cooling under severe braking.
Slotted or drilled & slotted oversize discs up to 16” (405mm) to ensure equal heat dissipation and increase thermal capacity while relieving the disc and brake pad surface free of excess debris.
-Rotora ceramic formulated pads designed for extreme street and track application with high co-efficient of friction and high temperature fade resistance.
-Rotora DOT compliant stainless steel braided brake lines to improve stiffer pedal feel and prevent brake hose expansion.
-Rotora carbon steel (SC45) mounting brackets (depending on application) and hardware.
Call or email for more info, or to purchase.
Old Mar 24, 2011 | 04:40 PM
1fastscion's Avatar
bump!
Old Apr 6, 2011 | 05:23 AM
NCCOOLJ98's Avatar
I wish the TC ones were this cheap
Old Apr 23, 2011 | 09:55 PM
Nos4you's Avatar
Will these fit xa w/ 15'' wheels?
JM Auto Racing
Dec 19, 2014 06:36 PM
Kiwibox
Dec 15, 2014 09:46 PM
George
Regional - Pacific South
200
Feb 11, 2006 01:48 PM
DenZinz
32
Feb 17, 2004 06:56 PM
scioninla
14
Oct 18, 2003 03:46 AM
