O2 sensor hard to get out of a 08 tc factory exhaust header
Hi just wanted to tell everyone I got my strup header today! Anyway everything went smoothly until I tried to take the O2 sensor out of the exhaust manifold, it wouldn't come out it was like it was welded in there. I manage to get it out after fighting with it for like 20 min, but I striped the threads all to hell, so I am going to have to get a new o2 sensor.
I manage to get it to temporly work until I get a new one, but its expensive, 200$! Has anyone else had this problem?
yeah this is a pretty common thing... toyota doesnt seem to like using anti seize compound in the factory... bastards. the only real thing you can do is put some form of penetrant oil on there (light amount or it can foul the sensor) and then work it back and forth a few times to really get it loose and then hit it with a thread file once its out to straighten the threads out a bit... and when you put it back in just make sure to put some anti seize on it. that part is very important... otherwise your just gonna have that problem again if you ever have to take the sensor back out... i actually had to by a thread chaser in a extra super huge size just for fixing O2 sensor bungs because of people not putting anti seize on them.
Yep no anti sieze and they are probably put in by a machine so they are 50/50 whether they come out or not......got lucky with mine as it did not want to come out and we managed to get it out in tact......call a few wrecking yards and see if you can get one for $20 before buying new.
Originally Posted by qrymson
i thought they were cross-threaded in. so it makes nearly impossible to remove. cause the same happened when i swapped my header. cheap to replace the bung. expensive to replace the sensor.
[quote="pioneer1976"]the key to removing them is to go slow and use heat if there stuck.[/quote
I tried heat, but they were stuck bad. It wouldn't of surprise me if the car was older, but the car was brand new, anyway lesson learned I guess LOL.
I wil ask the stupid question,what CEL eliminator and header,did you use the Weapon R eliminator as it won't throw a CEL,which would meen you fried the sensor welding it on,but the anti foulers can still throw CELs depending on what header you used.
Also when you put the new sensors in use anti sieze compound on them so they can come out again and take your time putting them in.
Also we are all here to help so in the future jsut ask and I am sure someone can give you a hand.
cut the weld very patiently with dremel and unscrew it,it might be ok to put new sensor into.
Hey Scion is going to give me 1/2 the price of the air/fuel sensor and 1/2 the price of the exhaust manifold, So I came out money ahead! It is around $285 total there going to give me, WOW. I encourage anyone else that has had this problem to contact scion!
Thanks for the help
Thanks for the help
WoW that is actually pretty cool of them......they really do try hard to work with the customer.I know there are horror stories as there always be.......but really they did step up and helped out....that is great.
