Stock head unit question
I have the pioneer base head unit in the IQ, (non navi unit). No plan for a new head unit in the near future, so was wondering if this pioneer deck has built in RCA's to add an external amp?
Thanks
Thanks
It's honestly the easiest thing ever. Your best bet is pull off the center piece where the 1,2,3,4 a/c control is, just pull it off with moderate pressure along the edges. Then work your way up with the next piece. Everything comes off fairly easy. The toughest piece is around the head unit itself and that just requires you to pull it forward.
Found a link to help us out on this one:
http://www.toyotaownersclub.com/foru...owtopic=136102
Complete how to with pics on removing head unit and replacing stereo.
If you look up under the dash on the driver side you will see a black rubber grommet that has a wire loom running thorough it. You can poke a hole in that grommet to run your wire or drill a new hole and use a rubber grommet to protect the wire.
Be careful to check on the engine side of the firewall before drilling to ensure there is nothing in the way that will be damaged by a drill bit.
clickclickw00t
02-18-2015 08:57 PM
wiltonhall
01-28-2015 03:46 PM
