07 Rearview mirror light crack
Hi guys, so i have an 07 tc that has the light portion of the left rearview mirror cracked and missing a piece. the light still works, but i can just see into it and see the bulb.
Do i have to re-buy the entire rearview mirror attachment, or is there that one piece of plastic that covers the light that i can buy? Links, etc would be helpful.
Cheers!
Cheers!
part 4 on this image, correct?
you have to buy the whole part. the lens and the plastic housing with the yellow LEDs soldered on is one solid assembly.
2007 Scion tC Parts - Sparks Toyota-Scion
yes you can just replace it if you ordered the part i linked, 4 on that diagram.
it isn't a bulb, there are LEDs soldered on. the whole thing is one piece.
you're not normally supposed to remove the lens or change the LEDs inside.
but some people do cut the lens off and solder in new LEDs, then glue it all back together.
here is a thread i found on the search for changing that part out (and how people could cut it open to change the LEDs)
https://www.scionlife.com/forums/tc-...-change-24700/
Yep i did! Thanks for the help!
Do you know how i would take the portion off? I think I read somewhere about pulling it off directly (the large piece on the back of the rearview mirror) and then take steps necessary from there. Not too sure though!
anyone?
Now I have 2 wires from the Replacement part that won't allow the socket to go in...
Not too sure if I'm supposed to strip some wires and stick those wires into them or not...Confusing as hell
without being able to see anything, the way your wording it is kinda confusing to me to be honest, you could have the wrong part or something.
i guess you'll have to strip the wires and solder them to make a connection with the new light.
Imagine picture 4 you posted, with 2 wires sticking out of the hole where the plug should be.
As a result, I can't plug it in. Hopefully this clears anything up.
minter66
Dec 15, 2014 01:45 PM
