5axis front lip problems
Old Sep 3, 2008 | 04:46 AM
jamessicat25's Avatar
PICS
Old Sep 3, 2008 | 05:20 AM
SquallLHeart's Avatar
^^ of what? a plain front bumper?
*smack*
Old Sep 3, 2008 | 05:27 AM
TylerC08's Avatar
Hmm...when it hit the ground, it could of caught a break in the cement which would easily rip it off...
Old Sep 3, 2008 | 06:30 AM
ProjectGreen's Avatar
Originally Posted by jamessicat25
PICS
Well, you can look in my profile and look at the picture of my bumper. That's what it looks like now.
Thats what I am thinking happened. I went back to the scene and you can clearly see where it scraped on the ground for about 10 feet up to where it finally broke off the car. The road starts going up hill around that area, so I think maybe it caught somewhere.
Ikona sent me an email saying he might be able to fix it.
Old Sep 3, 2008 | 07:13 AM
TylerC08's Avatar
4 cars ran over your lip...I think you should get a new one.
Best of luck with getting it all settled.
Old Sep 3, 2008 | 08:01 AM
SengTC3's Avatar
That is why I drilled a hole into my lip and bumper, jacked up the car, open the bottom side covering and put 2 bolts and nuts on the lip and bumper to hold it down.
Old Sep 3, 2008 | 10:45 AM
nebster's Avatar
i wouldn't have him do it anyway. read up on his rep around these parts
Old Sep 3, 2008 | 05:24 PM
hotboxn's Avatar
Team Echo
yep good luck having him repair anything in a timely fashion if at all......
Old Sep 3, 2008 | 06:13 PM
jackotamo's Avatar
You can try to bondo it
Old Sep 3, 2008 | 06:42 PM
What is bondo?
Old Sep 3, 2008 | 07:18 PM
EDDIEA123's Avatar
^X2
Old Sep 3, 2008 | 07:22 PM
iKONA's Avatar
What is bondo?
Bondo is a material used to resurface damage areas after the damage areas are put back together or repaired somewhat to shape. Bondon doesn't adhere well to Polyurethane or other plastic materials. If you wanted to repair it yourself Id use plastic repair putty. iIts not easy though.
Old Sep 5, 2008 | 04:00 AM
sky-on's Avatar
Bondo + Polyurethane = Epic Fail, its just going to crack.
Definitely shop error, the tape used by FIVEaxis is OEM grade 3M tape; I've hit tire tread on the freeway going 85 with the lip w/o it coming off, so I know that shizz is strong; what probably happened was the kit was fitted improperly, resulting in minimum contact and adhesion. Goodluck with picking up a new one, and I'd suggest you install it yourself this time =]
Old Sep 5, 2008 | 04:32 PM
xravexboix's Avatar
It's an installation error. When in stalling the lip kit, the areas the tape will be applied onto must be cleaned properly. Rubbing alcohol is the best bet. If there is still wax on the area the tape is applied, it will not hold and slips off easily.
Old Sep 7, 2008 | 07:12 AM
sonofabeoitch's Avatar
two little tricks i have learned from working at the body shop, light swipe of acetone(VERY LIGHT) to clean the surface, then a nice little coat of "Titer-bond" (adhesive promoter) works really well.
SuperXero
Jan 19, 2015 03:48 PM
757_BRDFLY
Jan 9, 2015 12:29 PM
ExtremeDimensions
Dec 18, 2014 04:47 PM
umnitza
Dec 1, 2014 06:26 PM
DenZinz
22
Nov 6, 2003 08:19 AM
