Another problem with my Angel Eye Projectors...
Old Sep 18, 2006 | 05:09 AM
mFrosty's Avatar
Default Another problem with my Angel Eye Projectors...
Well honestly it hasn't been the manufacturers fault so far with these headlights, just my stupidity...
Driver's side high beam not working as well as angel eye ring on the high beam. I already blew the running lights because the two wires touched while I had them on, so I replaced that fuse and now they're fine. But the high beam fuse isn't blow...
Any ideas? Thanks ahead of time...
Old Sep 18, 2006 | 11:20 AM
raWr215's Avatar
check your connection again, last time i blew a light, i checked the wrong fuse and was like lost for 1 hour! LOL, so try again? (clumbsy me)
Old Sep 18, 2006 | 01:24 PM
JfBriZ03's Avatar
I am actually having the same problem with my passenger side high beam. It has never worked form the beginning though.
Old Sep 18, 2006 | 01:31 PM
raWr215's Avatar
that sucks for you guys :T, umm... it still uses the 9005 lights? not wiring change/bulb changes etc with the headlamp?
also have you check the fuse?
Old Sep 18, 2006 | 01:58 PM
warpsycho's Avatar
what kind of headlight do you have? is it the OEM one or is it an ebay kit what brand / kit do you have? that can help a little into finding the problem.
Old Sep 18, 2006 | 02:35 PM
Dubcplaya069's Avatar
any of you guys having fogging issues mine wont stop fogging
Old Sep 18, 2006 | 03:07 PM
raWr215's Avatar
They are talking about the aftermarket ones
aftermarkets usually fogs up, bake it, gut it, use 3m windo-weld Ribbon Sealent or go to nissan and ask for their butyl rubber sealant, and reseal it if you are planning to stick with those headlights
Old Sep 18, 2006 | 03:23 PM
JfBriZ03's Avatar
I have the ebay ones. Mine started fogging, but they finally get fixed today! I am getting my HIDS installed and an Infinity Basslink II installed. The shop is going to fix the fogging headlight and look at the high beam problem.
Old Sep 18, 2006 | 04:53 PM
mFrosty's Avatar
I purchased mine from Viniati so I'm going to be getting a new set...
Although I'm gonna make one last attempt at trying to fix them today...
S7ephavs
Mar 22, 2015 12:09 PM
johnnytsunami
Mar 11, 2015 10:01 AM
sako
Mar 11, 2015 01:27 AM
tc_Jake
Dec 31, 2014 01:45 AM
umnitza
Dec 1, 2014 06:26 PM
