Attn Wheel Gurus
Old Oct 18, 2005 | 06:35 AM
SSM_tC's Avatar
Default Attn Wheel Gurus
For a tC on Tein H-techs
What wheel offset and tire size will I need to run if I am picking up 18x8 wheels to get as close to flush as possible to the fenders without rubbing?
Old Oct 18, 2005 | 03:13 PM
rhythmnsmoke's Avatar
Music City Scions
+35mm has seem to be the norm if you are running 8 or 8.5 in width.
Old Oct 18, 2005 | 03:55 PM
WeDriveScions's Avatar
I'm running 19x8's with 40 offset and 35 tires and have VERY RARE rubbing problems... only when loaded and fast big bumps.
Old Oct 18, 2005 | 03:58 PM
SSM_tC's Avatar
sweet... thanks for the info, guys.
Old Oct 18, 2005 | 04:26 PM
HKSpeed's Avatar
et35 on an 8 inch wheel is good. that would make the wheel stick out 22mm from stock. for the front thats about perfect. the rear can use a 5mm spacer. you'll need to roll the rear quarter panel lips if you run that spacer. the width of your tire also matters. a 215 tire would be a conservative size.
evolving_machine
Oct 21, 2023 01:16 PM
kleecker
Scion xB 2nd-Gen Wheel & Tire
May 22, 2016 06:10 AM
EcoxA
Mar 18, 2015 03:45 PM
GoodVibes
Mar 3, 2015 09:47 PM
