Bulb size question that I should probably know the answer to
So, I have Anzo's & I'm getting HIDs. Finally, after being in the scene for 3 years & spending an ungodly amount of money, the time has come! I know HIDs supposedly suck in Anzo's because of the cutoff, but quite frankly, I rarely drive the car at night so it won't be an issue. I'm also not considering a retrofit, so please don't recommend that to me. I know it's better, but I'm done spending anymore money on the car after I get it back this time around. So, my question, is the bulb size of the Anzo's still 9006 or is it different than the stock size?
Also, I could've sworn I had heard something about HIDs in Anzo's melting a harness or something, is it true? & what can I do to prevent it?
I feel like a noob asking these questions, lol.
Also, I could've sworn I had heard something about HIDs in Anzo's melting a harness or something, is it true? & what can I do to prevent it?:
<-------------sponsored (not by MobileHID)
If you're on your own, then most of the newer, more reputable kits come with relays that will prevent from melting any stock wiring harnesses. The relay will take the power for the ballasts directly from the battery, rather than thru the stock headlight wiring harness, ... but you probably knew that already.
rain7905643
Mar 14, 2015 12:48 AM
George
Regional - Pacific South
200
Feb 11, 2006 01:48 PM
Genesis
64
Jan 22, 2005 01:02 PM
