Electronic Flasher from SuperBrightLEDs
Old Jun 16, 2006 | 04:02 AM
czyker13's Avatar
Default Electronic Flasher from SuperBrightLEDs
Which electronic flasher should be used when replacing the turn signal bulbs with LEDs; CF13JL-02 (Japanese) or CF18-08 (Newer Toyotas)? And is this the best route to go?
http://www.superbrightleds.com/tail-brake-turn.html
Finally, if I replace the parking lights, do I need to add a 25 Ohm, 25 Watt Load Resistor to prevent bulb-out indicators?
Thanks
Old Dec 18, 2006 | 11:50 PM
noservice2001's Avatar
http://autolumination.com/equalizers.htm
yes, better than load equilizers which can get too hot and burn things....
if u use a flasher, u don't need load resistors (well autolumination told me this) as well since the flasher should take care of that... have u tried it yet?
i'm trying to figure out where the clicking is comming from.... where do you put the equilizer in an xB?
is it under the hood or under the steering column?
Old Dec 19, 2006 | 12:16 AM
chrischoi's Avatar
they try to say that every bulb is scientifically engineered. look at the pictures.. i beg to differ.
Old Dec 19, 2006 | 01:12 AM
SquallLHeart's Avatar
CF18-08
and there's no bulb-out thing for parking lights
Old Jan 29, 2008 | 12:31 AM
AC's Avatar
AC
i installed the cf18-08 flasher but now my signal lights don't work when i hit the lock button. the signals do work from the switches tho. is it a defective flasher?
SJMiller
May 26, 2021 05:18 PM
brett561tc
Sep 15, 2015 06:33 AM
SJMiller
Sep 12, 2015 06:33 PM
Armystrong
Aug 31, 2015 08:19 PM
dltjdgns66
Scion tC 1G ICE & Interior
Apr 15, 2015 07:59 AM
