help with bumper/ aftermarket headlights
Old Dec 29, 2012 | 12:44 AM
br0wnbandit's Avatar
Default help with bumper/ aftermarket headlights
hey guys,
i just replaced my stock headlights with some custom halo LED's and an HID kit on my tc. for some reason there is a gap on both sides right underneath the light and above the bumper. i was reading alot of stuff online and also went to some shops and they said that this is pretty common with aftermarket lights. was just wondering if there is a fix for it or anything i could buy to block the space as i do not want anything getting damaged due to rain, etc. any ideas?????
i got the spyder auto aftermarket halo projectors.
Old Dec 29, 2012 | 01:01 AM
Jon's Avatar
Jon
Moderator
Moderator
Quality control isn't very high when dealing with parts like that. The solution is to put your stock lights back in. The LEDs and halos will burn out eventually anyway.
Old Dec 29, 2012 | 05:11 AM
AnotherDude's Avatar
When you're going 50-60mph in the rain, it doesn't really matter if you have a small gap underneath your headlight, there's a ton of rain running through your engine bay anyway.
As for your issue, the only thing you can try to do is try to re-align the lights. You can loosen the bolts, move the light to where you want it, and tighten again. Aftermarket lights are known to have fitment issues, I have a few with mine, but i've adjusted it to where i think it'll be ok.
Old Dec 29, 2012 | 05:16 AM
RazorBladeNinja's Avatar
Aftermarket head/tail lights usually don't have that nice big bumper clip on them that the stock ones have. After installing my SpecD tails I noticed my rear bumper is a tad loose now, because they don't have that clip. I assume that's the case with your headlights.
Old Dec 29, 2012 | 03:59 PM
I tried doing that but then the sides and top get all jacked up. Fixed it to the point where there's like a little gap on the bottom. I'm going to go see if I could buy like a piece of rubber that will just sit in there to take up the space. Thanks alot..... Will update when I check it out
Old Dec 29, 2012 | 07:22 PM
stenger's Avatar
If you didn't transfer the bumper clips from the OEM's to the factory, this is likely your issue.
Old Dec 30, 2012 | 08:02 PM
You just saved my life bro. Nowhere in this video did it say anything about transferring clips. Now just got to find the time to take it apart again. Another issue I'm having is the hids aren't aimed rite so my lights suck in the dark. These new lights been a pain man. Considering just pitting my stock ones back on
Old Dec 30, 2012 | 08:55 PM
stenger's Avatar
Stock is the only way with headlights.
carid
Jun 18, 2015 01:20 PM
S7ephavs
Mar 22, 2015 12:09 PM
scsteven
Jan 25, 2015 01:06 AM
TheTripleC
Jan 4, 2015 06:46 PM
