help with wiring
ok, I'm on hidplanet and have asked on there, but nobody seems to be sure of how to wire 08 scion tc headlights. does anyone have a diagram or something I can look at? when I google them it brings up 07 diagrams instead of 08. The reason I ask is that I am still trying to figure out how to wire up a bi-xenon projector into where the standard projector was as well as place one where just the high beam was at. Anyone have any ideas?
I'm trying to get it done now because my engine is out and I'm working on fabricating mounts for a 2GR v-6.
Split the wires to your low-beam so that you have two sets of wires.
Run an HID ballast off of each set.
Use those ballasts to power the bulbs.
Take the wires from the projector for the bi-xenon solenoid and splice them so you have two sets of wires and run those to your high-beam connectors.
This should activate the solenoid when you flick the high-beams and that should be it.
I have an '06 with '08 headlights running the morimoto retro-quik bi-xenons in the stock location and retaining stock high-beams. Have been wanting to do a quad-xenon retrofit for a while. Would like to see pics when done.
domincnTC
Aug 4, 2015 01:47 PM
Wrencher
Jul 29, 2015 01:38 PM
semlin
Jul 29, 2015 02:07 AM
