HID Install help (McCulloch)
Old Dec 23, 2010 | 07:55 PM
NikostC's Avatar
Default HID Install help (McCulloch)
Hello, everyone, I currently have a 2010 scion tc and I recently got the McCulloch 6k HID kit with relay harness. I have looked for other threads but all the other relay harnesses look different/ fuse is in different location...
1.)I have a few questions, does the grounding wire go on the frame near where the cold air intake was installed?
2.)The other red wire is supposed to go to the battery right?
3.)What do I do with the other two black and white wires?
4.)How do I connect the two HID lights?
5.)I briefly looked at the lights in my car and tried to take off the whole bulb with the cylinder plastic housing, but only the bulb would twist off, not the whole thing(didn't have much time to check, I had to go to work.).
Any Help is appreciated, Thanks.
Old Dec 23, 2010 | 09:26 PM
paolodoctolero's Avatar
You're correct the first one is for the battery and the other one is for ground..
The two black wire is the one that goes to the source of your original bulb..
Old Dec 24, 2010 | 03:30 PM
lltysonll's Avatar
this may help it may not...
http://home.comcast.net/~patcourt/instructions/page1.htm
did it not come with instructions? should be easy to install.
http://www.tvclip.biz/video/YDt4IeCR...tallation.html
Old Dec 26, 2010 | 01:28 AM
NikostC's Avatar
thanks man got it.
Old Jan 2, 2011 | 05:35 PM
NikostC's Avatar
does it matter if the HID bulbs are not turned in the same angle? my right bulb is horizontal in the headlight and the left is vertical.
Old Jan 4, 2011 | 06:21 PM
It matters.. Try it on the wall and you will see the difference of the light output..
SuBSiN
Mar 13, 2015 04:02 AM
Frustratez
Feb 26, 2015 04:03 PM
clickclickw00t
Feb 18, 2015 08:57 PM
tc_Jake
Dec 31, 2014 01:45 AM
TheRedBox
31
Dec 2, 2003 04:53 PM
