how to make my hazards flash with unlock/lock?
Old Jun 19, 2008 | 08:45 PM
howiedds's Avatar
Default how to make my hazards flash with unlock/lock?
i have the viper 5900alarm...but the lights dont flash when i lock/un lock anymore (unless i use the scion keyless remote) ...any suggestions from some alarm pros??
Old Jun 20, 2008 | 12:35 AM
tkevin07's Avatar
umm ur alarm tech probably didnt connect the wire for the lights or u have to configure it to flash, look in ur manual first to see if u can set it up, if u do it and theres still no flash the alarm wasnt fully hooked up
Old Jun 20, 2008 | 03:00 PM
HR_Guy's Avatar
Have the place that installed it put in a $5 relay to connect it to the turn signals when you arm/disarm it. That's how I got mine setup because I didn't like the parkings lights flashing.
Old Jun 20, 2008 | 09:52 PM
mattieg's Avatar
It will be a white wire with a 15 amp red fuse. If it use to flash then the fuse might be blown. But for the hazards to flash its actually a negative pulse. Its an orange wire i the A/C control assembly, pin 28. If you want to do this you will need to get a relay. Hook 85 to the white wire from the 5900, 86 to ground, 30 (common) to ground and 87 to the orange wire in the a/c control assembly. Hope this helps.
Old Jun 21, 2008 | 08:14 PM
beerrunninthetc's Avatar
there is a how to video on youtube.
correction..how to make a chirp sound.
missing_image
Feb 7, 2015 07:18 PM
paul_dezod
Scion tC 1G Wheel & Tire
Dec 10, 2014 06:46 PM
bruceb25
Nov 23, 2014 04:52 AM
kagero79
9
Nov 22, 2003 09:27 AM
deathcabforme
15
Oct 19, 2003 03:18 AM
