how to remove lower grille?
Hey I was trying to swap out my stock front turn signal bulbs for some silverstars (which by the way is a _____ to do), and turns out I bought the wrong bulb size; the silverstar bulb didnt click in correctly and I ended up dropping it into the bay. I think I can get it if I take out the lower grille. But I'm not exactly sure how to do that. I searched and everything I found just said "pop it out." I gave it a tug but it didn't want to come out.
Also, what is the correct bulb size? all it says in the manual is "wedge base bulb."
Originally Posted by Aroddalobster
kick it REALLY hard. hehe but seriously, it goes inwards towards the engine. not pull towards the front.
turn signals as in the ones towards the middle? the small amber colored bulbs? those are.. 7440 i think?
Originally Posted by AcidDrop
you do not have to remove the lower grill to replace the turn signals, if you do then you won't be able to reach them.
i know it's about the bulbs, but i am also referring to the topic 7440 is the turn signal, 194 for parking lights and side marker, 9006 for low beam, and 9005 for high beam there all bulbs that go in our headlight housing.
Edit:as for removing the lower grill, just becareful not to bent the clips from the bumper.
can you see where the bulb landed? is it on top of that little piece of underbody that's connected to the bumper? if so, i would just get under and punch that part so the bulb will jump around and maybe it'll get into an easier-to-reach place, or even fall out.
10gxiong
Feb 21, 2015 12:53 PM
viciouzgamer
Feb 18, 2015 03:26 PM
randode
9
Oct 25, 2003 04:58 AM
