View Poll Results: which lambodoor is better?
Voters: 8. You may not vote on this poll
I need to know which Lambo doors are Better?
gt factory by far. they open all the way up and pretty straight. 3 of my friends have them on thier escalade, civic, and f150 and they are by far the best kit. they are a biscut to install tho. no where close to bolt on. ive heard great things about the jt autostyle kits too. but they dont open all the way. i say go for the gt factory. i havent seen a single tc with that kit yet.
I got custom hand made kit for like 600 way better than other kit for the tC and they are 90 deg.
The hinge is more than double the thickness than the others so they don't wobble at all.
____
____
this guy makes them in miami from like 1 inch steel then he welds it all up taked him about to days to start and install.
he has people wthere with all of those kits on there cars and none feel as good as custom..
pretty much lol.. but it would be 900 for you any way i got hooked up. are any of the other kits really 90 deg? the guy put to shocks on the sides so that when you pull the handle the door shoot oout tot he side kinda like a pop lock and with pull of the pinky the door will open all y itself its pretty sick. good luck with your choice
the jt autostyles aint 90 degree I can tell you that now. the way the hinges are made won't let it go 90 degrees, I think its 60-75 degrees is all it can go without either the door or the hinge hitting the front fender. but its worth the $900 they're nickel-plated and comes with all mounting hardware for a direct bolt-on kit.
Thomas
Thomas
Has no one heard of LSD? This kit is the best and it is the only one that is crash test rated. People with JTA said mine were nicer than the rest. And its completely bolt on, perfect fitment.
WWW.LSD-DOORS.COM
Check it out.
WWW.LSD-DOORS.COM
Check it out.
i think if i had the moeny i would get them.
