My Headlight....
Old Sep 18, 2006 | 06:23 PM
interianoh's Avatar
Default My Headlight....
I cant figure it out why my driving side headlight bulb runs out so fast. I bought a headlight bulb and after using it for three weeks it ran out. Any ideas why it might burn in a couple of weeks? THANKS
Old Sep 18, 2006 | 06:27 PM
dannygenio's Avatar
may be you touched the bulbs (glass) with your hands...while you installing it.. make sure you don;t touch that glass part
Old Sep 18, 2006 | 06:29 PM
web's Avatar
web
Wear latex gloves. It's the best way to get 0 oil on the bulb. Also, don't do it if it's really humid...i.e foggy or misty outside.
Old Sep 18, 2006 | 06:30 PM
interianoh's Avatar
im always careful while installing the bulb and have not touched the glass....btw i have changed the bulb a couple of times..
Old Sep 18, 2006 | 06:32 PM
web's Avatar
web
Check your fuses. Make sure they aren't cracked. Could be causing a short. Do you have anything else electrical done to your car?
Old Sep 18, 2006 | 06:34 PM
interianoh's Avatar
i guess not...im a noob when it comes to cars....i installed a amp and subwoofer...i dont know if that will count as one
Old Sep 18, 2006 | 06:35 PM
web's Avatar
web
It does b/c you had to hook up wires right? Make sure all your connections are firmly in place and check ALL of your grounds. Any loose ends may cause a short in unrelated areas of the car. Good luck.
Old Sep 18, 2006 | 06:37 PM
interianoh's Avatar
best buy did the installation...but um the power wire sometimes gets disconnected from the amp and that might would be the issue. I will go ahead and check the fuses as well. Thanks WEB!!
Old Sep 18, 2006 | 06:39 PM
web's Avatar
web
hhmmm WorstBuy. I hate that company b/c they are horrible at audio install. They shortcut too much. Hope you find your problem.
Old Sep 18, 2006 | 11:38 PM
interianoh's Avatar
ok...well i replaced the bulb this evening and managed to take my time and not touch the glass...now about the fuse...theres a lot of fuses onto the tC. is there a specific fuse that i need to look for or i have to take a look at them every single one? Thanks
Old Sep 19, 2006 | 12:08 AM
Noodle's Avatar
What bulb are you using? some cheap aftermarket ones will die out in weeks
Old Sep 19, 2006 | 01:09 AM
freeflowing's Avatar
you do have a short happening somewhere
do your self a favor and read you manual on fuse locations. i can tell you that the fuse your looking for is right under the steering shaft area. never let bestbuy do anything for you when you can doit yourself. scionlife is always here to help noobs just use the search
use experience techs if want the best results.
Old Sep 19, 2006 | 01:19 AM
magyver's Avatar
word on the worstbuy.. we fix there f-ups everyday... shortcuts arent the word for it...
yeah, you could have a short.. but its not there all the time.. if you had a short, your fuse should blow.. it sounds like the headlight wires themselves could be loose somplace and maybe rubbing up against a ground or the like.. check where they ran the wires through the firewall and see if they drilled into any wires and what not.. but, usualy, that would cause them both to go.. so if its just one side, then it leads me to believe that there is a loose ground or loose power wire that when you hit a bump its gettin that sides bulb.. not sure on how the wires are run yet as i havent taken this car apart yet.. YET.. so not sure if they run to the fuse/relays seperatly or jsut T off.. if they T off, then the problem is your install, cause if one was to go, they would both go as there is no fuse/relay/ between them.. so if one shorts, they both do..
Old Sep 19, 2006 | 03:57 AM
interianoh's Avatar
aight..thanks for everyones replies....i will make my life easier and i will take it to the dealer...i will ask someone to help me on this...appreciate everyones help!!
excb7
Apr 23, 2015 10:02 AM
Keith
Scion tC 1G Aero & Exterior
10
May 8, 2008 10:06 AM
piercedlip81
May 24, 2005 07:03 PM
