n e 1 installed wilwoods big brake kit?
The Wilwood calipers are quite a bit smaller than our StopTech calipers, so you might be OK. I would recommend seeing it they have any kind of wheel fitment template that can be placed within your wheels to verify fitment like ours available here:
Instructions: http://www.stoptech.com/tech_info/wheel_fitment.shtml
Template: http://www.stoptech.com/tech_info/ch...55-2430-02.pdf
I'd suggest Stoptech over Wilwood anyday though.... Seen the little wilwoods on RaamAudio's tC and seen and driven a tC with stoptechs and was much more impressed with them... Much larger caliper and rotor and beautiful construction... brake response was killer too.
Originally Posted by 06SuperWhite_SoCal_tC
So the StopTech breaks will fit within the stock wheels? I knew WillWood would fit, but i thought ST was too big?
I have since installed a different set of wheels that dont require any spacers to be used, but I am considering getting 15mm spacers for the front and rear of my car to use the stock wheels and tires for road trips when I dont want to wear out my good tires. There should be no fear in running a spacer, especially if they are hubcentric. The H&R kits are very nice and include new longer wheel studs to ensure there wont be any issues with the lugnuts not being threaded deeply enough.
xBSciontist
Jun 18, 2019 03:06 PM
VCUBoy714
Scion tC 1G ICE & Interior
Jan 5, 2015 08:46 PM
JM Auto Racing
Dec 19, 2014 06:36 PM
DenZinz
32
Feb 17, 2004 06:56 PM
scioninla
14
Oct 18, 2003 03:46 AM
