need tyc help!!
so one of my tyc's has condensation.
is it safe to bake my tail light to take the condensation out?
or will the heat burn out the leds?
thanks in advance,
mike
thanks in advance,
mike
Oh. In that case, I'd try the sun before the oven. I don't want to say 225* with the door open would be ok. That works for headlights, but the plastic is a lot thicker since they're made to withstand heat.
The moisture will come back if the tail lights aren't sealed, try using some Black RTV (see photo) to seal them up. A nice thin bead around the out edge and then a wet finger to smooth it out works great! The water may also be entering from behind the tail light, check the rubber/foam gasket for tares.
Btp907
Sep 11, 2015 11:46 PM
