Painting Header Cover..
Hey guys whats up? I dont thik ill be getting headers for a long long long x 10 time..so i was wondering ...
how do I paint the acctuall header cover? like how do i get it ouch and such? any resonce and tips for this project will be greatly valued!
Kishan P.
Kishan P.
Get it powder coated like this guy...
https://www.scionlife.com/forums/vie...253&highlight=
Looks hawt and will look professional! Call around in your area. Shouldn't cost too much.
It's easy.. go to autozone and get the high temp 1300-2000 degrees temp (just to be safe) paint.. its got 3 or 4 bolts.. the difficult part is taking it off without removing the o2 sensor.. be careful and it'll pop off..
500º paint is plenty. The ultra-high temp stuff has to be baked, and the cover won't get hot enough to cure the paint. Eventually, the paint will get sooty and rub off. I painted the cover in my tC in August of '05, Duplicolor 500º Engine Paint, Low-Gloss Black.
Remove the 3 bolts and one nut holding on the cover.
To make things easy on yourself, use pliers or vise grips to remove the stud that the nut was on. It comes off fairly easily.
Unplug the O2 where it clips into the gray plug at the front upper righthand corner of the motor.
Slide the cover up the wire and off.
Paint it.
Put it back on, admire your work.
Paint it.
i dont like it personally.....but that battery cover u have is sweet....hey i do wanna paint my engine cover but i wanna do my SL name in graffitti wit skulls around it in white black and neon green....since im gonna put a uv cathode under my hood......i think the light will make those colors stand out very nice!!
Bmfxtreme
Aug 18, 2015 01:25 AM
