painting the valve cover
Old Oct 30, 2006 | 08:13 PM
ziobep's Avatar
Default painting the valve cover
what kinda of paint should be used when painting the engine valve cover??
Old Oct 30, 2006 | 08:14 PM
jallamas's Avatar
Hi Temp!
Old Oct 30, 2006 | 08:16 PM
ziobep's Avatar
yeah i know def hi temp but how to get the glossy look?
Old Oct 30, 2006 | 08:44 PM
Neothin's Avatar
mine's is just automotive paint :-/ same stuff used on the exterior of the car.
Old Oct 30, 2006 | 08:46 PM
JoMac's Avatar
I just used regular automotive paint on mine also.
Old Oct 30, 2006 | 08:50 PM
TCpete's Avatar
use VHT paint.. you can also use hi temp but you need to prep the valve cover
Old Oct 30, 2006 | 10:43 PM
carmel33's Avatar
I still got a lot of duplicolor caliper paint left...can I just paint the cover with that and it will look glossy like the calipers?
Old Oct 30, 2006 | 11:24 PM
Dr_Isotope's Avatar
This comes around again to whether people are talking about the engine cover, which is a molded piece of plastic, or the valve cover, which is a piece of cast aluminum.
For the plastic piece, use whatever paint you like.
For the aluminum piece, some type of heat-resistant paint is recommended.
There are gloss hi-temp clearcoats. You can always get the gloss that way.
Old Oct 31, 2006 | 12:14 AM
Hyghgynx's Avatar
If you're talking about the Engine Cover; use Dulpi-Color High Temp paint. You don't really need to prep other than cleaning the engine cover really good with a mineral solution or rubbing alcohol. Paint 3-4 EVEN coats and let them dry thoroughly. After they dry, use 3-4 coats of clear and wahlah!!
Purdy Engine Cover! Painted mine 4 months ago. No problems yet.
tckid21
Mar 12, 2017 09:16 PM
P944
Apr 30, 2015 06:04 PM
SeT
Apr 1, 2015 07:39 PM
carid
Feb 18, 2015 09:10 AM
xxmanrd92xx
11
Feb 4, 2015 01:40 AM
