Power Slot Big Break Kit
Old Jul 14, 2005 | 08:38 PM
MysTiKchRis's Avatar
Default Power Slot Big Break Kit
I was looking around and came across this Big Break Kit by power slot that uses your stock Caliper. Its a lot cheaper than other big break kits what do you guys think?
http://www.tirerack.com/brakes/brake...ors&perfCode=S
Old Jul 14, 2005 | 08:52 PM
ack154's Avatar
Part of the reason for getting a BBK is to also get better calipers (more pistons). So I think this would probably be pretty useless. If this is all someone is looking to do, you could easily just get a set of drilled and slotted rotors only. Probably quite a bit cheaper than what these people want.
Old Jul 14, 2005 | 09:08 PM
t_C's Avatar
t_C
Default Bigger Rotors will do the trick
Larger rotors won't give you additional braking force. They WILL however allow you to slow the car down faster beacuse the increased diameter allows you to use the force your stock calipers provide more effectively.
I have used powerslots of a larger diameter on several vehicles (much bigger and heavier than the tC) and have always been impressed with the result.
Old Jul 14, 2005 | 09:15 PM
squirrel's Avatar
I've seen it installed and the new rotor is nice and thick. True you should get a larger contact patch caliper, but upgrading brake pads with the new rotor should do nicely for the tC.
Old Jul 14, 2005 | 09:21 PM
TurboMe's Avatar
wont the black finish start to wear off?
Old Jul 14, 2005 | 11:19 PM
Yea I was thinking that too?
Old Jul 14, 2005 | 11:26 PM
squirrel's Avatar
Chris, the tC I was speaking of was at Tracy Toyota last sunday.
Old Jul 15, 2005 | 01:27 AM
Yea I think I saw it but didn’t pay attention "the SW one?". I just noticed he had the red painted stock calipers and black rotors. Didn’t think it was a big break kit because of the calipers. Should of taken a closer look.
missing_image
Feb 7, 2015 07:18 PM
JM Auto Racing
Dec 19, 2014 06:36 PM
Monkeywrench
Aug 11, 2004 02:55 PM
Docofmind
Nov 11, 2003 07:09 PM
scioninla
14
Oct 18, 2003 03:46 AM
