removed exhaust question
i was wondering if anyone with a removed exhaust has any dyno numbers? and if so is it removed from the axle or the s-pipe?what im trying to say is, will there be more gain with it removed from the s-pipe or axle.i already found that removed at the axle will give a gain of 5hp. link to source (https://www.scionlife.com/forums/viewtopic.php?t=80070)
if gains are good im planning on having an electrical cutoff valve
should be about the same.
if you remove it from the s-pipe back or axle-back the gains will be negligible.
also, cut-offs wont get you a gain of HP if thats what your thinking, on NA we need back pressure, its turbos that live off of cut-offs, not NA.
Jumphiggggg
Feb 13, 2015 04:05 PM
Godfryness
Jan 2, 2015 11:18 PM
