RS1 style front lip help.
Old Apr 3, 2012 | 05:39 PM
Clot's Avatar
Default RS1 style front lip help.
I recently bought this front lip from ebay. Today I tried a fitment test, and the fitting was horrible. Has anyone on here experienced this? I noticed the middle area which rests on the oem bumper is wider in width but shorter in length.
Old Apr 3, 2012 | 06:25 PM
my06tc's Avatar
is that abs plastic...doesnt look like a legit rs1 lip,cause i had one and the middle flap wasnt that long,meanning i was able to use it with the oem grill,doesnt look like a legit rs1 lip to me,but i could be wrong,if it doesnt fit,contact the seller
testa422's Avatar
did you buy it off ebay? mine from racing solution themselves was SPOT ON!
Old Apr 3, 2012 | 06:28 PM
Bum's Avatar
Bum
You have to either remove the grill or take a dremel to the center peice and make it way more shallow in order for it to fit correctly. That's your problem because I had the same issue.
Old Apr 3, 2012 | 06:33 PM
Clot's Avatar
Yes I got these from ebay from xcessmotors. It is not ABS, it is Polyurethane. And not it is not a legit RS1 lip from RacingSolution. Either they sent me a wrong one or the fitting is just way off.
Old Apr 3, 2012 | 06:36 PM
RacingSolution's Avatar
Strictly Scionized
Yah like Bum said, take a dremel and cut some of that flap in the middle.. it's hitting the grill
Old Apr 3, 2012 | 06:37 PM
Clot's Avatar
I was thinking of removing the lower grill, but I was expecting the lip to fit well without any modification or adjustment. :?
Old Apr 3, 2012 | 07:19 PM
my06tc's Avatar
i know the rs1 lip i had was abs plastic,fit perfect with oem grill
Old Apr 3, 2012 | 07:25 PM
Strictly Scionized
That lip looks like abs plastic btw.. I don't think its polyurethane as they advertise on their ebay store
Old Apr 3, 2012 | 07:32 PM
TheShirk's Avatar
Did the packaging say 'HU racing' or something like that? If so, its the exact same one that racing solution sells.
If thats the case, you'll have to cut a little bit of the plastic off near the grille so that it can fit nicely. I have done this for 2 tCs and it looks good
Old Apr 3, 2012 | 08:29 PM
scionic128's Avatar
i got the RS1 lip from racing solutions and didnt have to modify it at all to fit. luck of the draw i guess?
Old Apr 4, 2012 | 12:52 AM
my06tc's Avatar
you shouldnt have to modify it,unless these things change since when i had it,should be abs plastic,and good fitmen,a few other ppl i know that have it too,and its plastic and fit perfect
Old Apr 4, 2012 | 12:54 AM
TeeCizzle's Avatar
I dont think that is an "Authentic" RS1 lip....it should of fitted A LOT better than that.
Should fit like a glove!
Old Apr 4, 2012 | 01:01 AM
testa422's Avatar
yea definately a knock-off...like i said and what my06tc said, if its authentic, it will fit perfectly
Old Apr 4, 2012 | 01:42 AM
Clot's Avatar
Thanks a lot for your inputs, I really appreciate it. First when I bought the lip, I expected it to fit without any modification. Since mod on this one is needed, I went for it. I cut off that center part, and I was able to get it fit right. Thank you all again for the help
Old Apr 4, 2012 | 03:13 AM
TheShirk's Avatar
Sweet!
Old Apr 4, 2012 | 01:52 PM
my06tc's Avatar
if your happy with it,thats all that counts....
Old Apr 13, 2012 | 07:18 AM
Clot's Avatar
Had a chance to take a quick pic :D. Ignore the unmatched side mirrors. I'm going to finish the other side soon.
viciouzgamer
Feb 18, 2015 03:26 PM
SuperXero
Jan 19, 2015 03:48 PM
757_BRDFLY
Jan 9, 2015 12:29 PM
ExtremeDimensions
Dec 18, 2014 04:47 PM
umnitza
Dec 1, 2014 06:26 PM
