Seibon hood issues...
I purchased an OEM CF hood for my '06 back in March and it has cracked across the front. Its about 5" and basically above the hood latch...I have asked around locally and found 2 others that currently have the same thing going one, plus one guy in OR that haad the same problem but Seibon fixed it. Basically what I am asking has anyone had this same issue? I went back to the shop I got it from and they said that Seibon would not warranty it...that ____ed me off. I have a sent a letter off to Seibon to voice my concerns and I will follow up here, especailly if others have/are having this same problem.
let me know...
let me know...
thats really odd, ive had my hood on for over a year now with no cracks let alone no issues at all :-/ and you only had the hood on for 2 months?!?! seibon should warranty it since it has not been on your car that long . they are usually very reliable u have any pics of the crack? GL ! def watching this thread
ive had my Seibon oem style hood for a year now. no issues at all. the only crack/chip is from rock and road debris...just 1 at the very front of the hood and i consider that normal wear and tear type of damage.
I liked the weave better in the VIS and that is what I ordered but I was told like you said that Seibon was better. I close my hood with 2 hands, the shop adjusted my hood stops down becasue it was difficult to close to begin with, this is the 3rd hood i have had on my car and the only one I have had a problem with.
I just got word from another local member as well so that brings it to 4 people all in the local area that have this same issue. I know 2 of them are most likely from improper closure but I just can't believe that not only are they aware of the problem but do not do anything to help prevent/ fix it. They say its not a manufacturer defect, but if 4 of the 4 people w/ Seibon hoods that I have talked to locally all have this same issue, there is something going on.
i talked to some of my guys that have cf hoods also and do a lot of bodywork professionally and they have come to the same conclusion I have. It may have not been installed properly. did all 4p eople that you know have the same people install it? On my hood we moved the latch mechanism down.
It sounds like the latch mechanism on the vehicle is not lined up / adjusted correctly with the latch bracket on the hood. So when you close the hood, the latch mechanism is sticking up too far and is hitting the exposed underside of the hood causing minor cracks to appear on the surface of the hood
Erik let me take a look at it,it should close like mine and Brads do,I adjusted both,mine was majorly adjusted for those that know the story.....lol........but let me look at it,I can tell you pretty quickly if it was installed wrong.
is the crack on the CF top, or underneath in the fiberglass? if its underneath, then hood pins or latches should take care of the problem right?
i have a seibon oem hood going on 2 years old, still looks great and no damage anywhere!
