Seibon hood issues...
Should of let my drunk butt install it...........you know I used to do auto body till my lungs gave out.........I have done ahood or two.........lol........I will check it out,probably an easy fix.
lower the bump stops,loosen the latch onthe frame of the engine bay,remove the grille.
Set hood down to latch it,adjust sides stops up till they are flush with the fenders.
takes a few times.......tighten the latch,undo hood and then open and set down till it starts to latch,then give a slight push down and it should close perfectly,if not keep adjusting the latch.
My Kami hood came with the wrong latch on it and I had to relocate my latch completely down 1.25",so my latch is not visable through my doc i radiator panel........one of a kind sort of.
