Spec tC Roof Swap (Moonroof to Sunroof)
Old May 11, 2009 | 04:13 PM
  #41
kiss_kiss_kill's Avatar
Originally Posted by CarbonXe
^Way to say the same thing CarbonXe did, dee dee dee.
p.s. I'VE BEEN DRIVING MY TC FOR 3 DAYS NOW. in yo face!
Please never say 'dee dee dee' ever again.
WHY
Old May 11, 2009 | 04:16 PM
  #42
ecko04's Avatar
Question...are the spec headliners different?
Headliners are the same.
Stock interior cloth color is different, the spec's is better than the base IMO.
I think the only difference is for the sunroof switch, could be wrong.
The spec doesn't have that humongous sunroof switch, I hate to state the obvious, I know you knew that.
The harness runs from the rear dome light, to the front dome light, to the sunroof motor to a spot on drivers side above the fuse box where it plug in and there is another plug with 1 pink wire in it that isn't used.
The spec harness is the same minus the plug that goes to the sunroof motor.
Old May 11, 2009 | 04:18 PM
  #43
ecko04's Avatar
WHY
Hence the reason why photobucket sucks!!! No bandwidth
Old May 11, 2009 | 04:21 PM
  #44
Originally Posted by ecko04
WHY
Worked fine for me.
Old May 11, 2009 | 04:25 PM
  #45
ecko04's Avatar
Worked fine for me.
Even further proof as to why photobucket sucks!! It sporadically works!
Old May 11, 2009 | 04:30 PM
  #46
lol
Old May 11, 2009 | 04:39 PM
  #47
rosedaleny806's Avatar
u know I hate u, right?
I actually IMed u the other nite asking u how the car was and wat u dyno'd at
Old May 11, 2009 | 05:33 PM
  #48
CarbonXe's Avatar
WHY
[img]https://i41.tinypic.com/29ercz.jpg[/mg]
Because Mencia was never funny, will never be funny, and will always remain a complete waste of space.
Old May 12, 2009 | 04:56 PM
  #49
viventi's Avatar
Jon, youre such a hater sometimes, lol.
Old May 12, 2009 | 05:09 PM
  #50
CarbonXe's Avatar
You actually think Mencia is funny? He steals other peoples material and destroys it.
Old May 12, 2009 | 05:13 PM
  #51
viventi's Avatar
Do I think he's funny? No...you on the other hand though.
Old Nov 11, 2011 | 03:57 AM
  #52
larry656's Avatar
hey do you still need the . sun roof . for your scion tc if you do hit me up . i have one .i also have a set of vertical doorskit for a tc
Old Nov 11, 2011 | 04:15 AM
  #53
larry656's Avatar
hey guys . i have a set of lambo doors for a scion tc. 2 month old
for sale . also have sun roof parts. any one interested hit me up
Old Nov 11, 2011 | 10:43 PM
  #54
Dam262a's Avatar
you know this thread is 2 years old bro, i doubt anyone needs your stuff fyi
Old Jun 14, 2016 | 04:19 AM
  #55
El_paisa_1990's Avatar
Did you have to take down da skin fron da inside? You dont happen to have made a video? Since theres little on scions
Old Jun 25, 2018 | 03:46 PM
  #56
AustinhawkinstC2p0's Avatar
Default Couldn’t find enough info so thought I would try to help
Still got confused and couldn’t get an exact answer on what bolts or how many, so I thought I could try and help out anyone doing this in the future. So I just finished yesterday, and was not able to get a good answer on how this works, so in case anyone is wondering,
there are 24 bolts that need to come off, all 10mm you will need an extended socket for the rear bolts, once the interior is off, there are holes by the dome lights on the front and back that are all going to come out pretty easily, 4 on the back, 4 on the front making 8 bolts,
then you will go to the sides by the doors, if you look closely all the bolts look the same and you can tell which 4 are going to be holding the sides on, build all 8, 4 from the driver side, 4 from the passenger side, then there are 8 bolts left.
If you look up by the air bags by the front windows there are 2 separate brackets one towards the middle and one towards the front, unbolt all 8, 4 on passenger, 4 on driver side (these bolts are a little smaller), now that all 24 bolts are off I found that mine were stock on
with glue as well, so if you just push up slightly hard on each corner with even pressure for a decent amount of time, it should pop right out and sit on the roof of your car, it is pretty heavy so you may need some help removing it off the car without scratching it.
Hope this was some what of a help to someone! (I would say this takes close to an hour maybe 1:3)
MightyP
Scion tC 2G Aero & Exterior
Sep 20, 2011 05:01 PM
DesiratC
Mar 21, 2008 03:49 AM
trdmaster
Dec 5, 2007 09:55 AM
Nightshift
26
Mar 4, 2006 02:31 AM
tallguy4u2luv
Jun 9, 2005 12:57 AM
