Transfering Windshield Washers To Another Hood
Old Mar 23, 2008 | 08:55 AM
Dilirious's Avatar
Default Transfering Windshield Washers To Another Hood
Hi,
Just installed my cf vis oem hood today and fits perfectly, now the only problem I am having now is transfering over the windshield washer to my new hood. I can not take off the washer from the stock hood and have no idea how to do it.
So you guys who have done the installation your self how did you go about removing it and installing it to the new hood.
I will post pictures tomorrow when there is light.
Thanks,
Jeremy
Old Mar 24, 2008 | 03:52 AM
Dilirious's Avatar
Bump
Old Mar 24, 2008 | 03:58 AM
silverstreaktc's Avatar
you spelled your sn wrong...did u try taking a wrench and holding it down while someone holds the nozzle?
Old Mar 24, 2008 | 06:15 AM
SquallLHeart's Avatar
i didn't install it into my new hood.
nozzleless = looks cleaaan
uhmm.. you take them out from the bottom.
Dilirious's Avatar
no thats how its meant to be spelled, and i will try doing that tomorrow and see if that works thanks
Old Mar 24, 2008 | 07:39 AM
tico4csun's Avatar
Team ScionTific
Keep the screen name. It goes along with the meaning. I'm baffled no one's figured that out
Old Mar 24, 2008 | 12:49 PM
ExpresScion's Avatar
When you have the stock hood off, get a wide flat head screwdriver and get behind it. Have someone on the other side to help hold it when one end pops out. You will see the clips on each end of it, and just push down on them with the screwdriver, and it will pop one end out. Do that to the other and you are good to go.
Old Mar 24, 2008 | 07:04 PM
Dilirious's Avatar
Thanks Expres that work perfectly, but now problem is that the predrilled holes on the vis oem hood are not big enough for those, saw a post from someother guy who did it and said he had to shave the sides down, but does anyone else have another idea how to get it on may another one that may fit it,
Thanks
Jeremy
Old Jun 23, 2008 | 12:32 AM
KiKaZ-tC's Avatar
I'm trying to remove my washers but I need to remove the black cardboard piece under the hood which is held on by several black press in clips. Anyone know how to remove these clips holding the cardboard covering the washer lines?
Old Jun 23, 2008 | 12:47 AM
Ukno0003's Avatar
just pop them off like any other clip witha screwdriver or something
Old Jun 23, 2008 | 01:46 AM
svencarlson07's Avatar
i just went and bought aftermarket ones where the clips are a little bit smaller and didnt have to shave them down as much
Old Jun 23, 2008 | 01:51 AM
there's an actual tool made to pop those things off easily if you just look in any automobile store.
otherwise a flathead screwdriver and some patience would be your other choice.
Old Jun 24, 2008 | 02:48 AM
Need4Bass05's Avatar
Yea I just bought one for myself. It was like 5 bucks. Makes the job alot easier and you dont have to worry about messin up the grip on the pins. Got it at and autozone.
Old Jun 24, 2008 | 04:46 AM
REVLIMITER's Avatar
i saw a tc on here like 5months ago with the wiper blades with washer nozel built in may be a good option
Old Jun 28, 2008 | 05:14 AM
mystik's Avatar
CinSity Scions
the heatshield (the black foam thing under the hood) can be removed by using a screwdriver, and prying the plastic tabs and then pulling on the plastic tabs and it should pop out. it takes a bit of effort, but they are quite durable. i also had trouble with mine, but after a few vicious attempts, one popped out. but i guess the tool works the same, but for 5$ lol
yupinmytC
22
Jul 27, 2024 07:08 PM
rvascion
Nov 12, 2020 03:23 AM
mikeac
Sep 15, 2015 03:24 PM
BlingSlade
Sep 5, 2015 08:52 AM
Bimfi
Sep 4, 2015 08:15 PM
